techdraw with multiple parts
- robotMarvin
hi everyone i'm using freecad 0.17 and created a drawing with part and part design. When i wanted to make a drawing with techdraw, i coul only choose one part. but i need all the parts in my drawing. How is this achieved.
I also drew it in freecad 0.16 Revision 6706/6707 but i had the same results. where do i go wrong?
- waterinlaat.fcstd
- (21.57 KiB) Downloaded 63 times
- wandererfan
Re: techdraw with multiple parts
Select your parts, then use MultiView wfrobotMarvin wrote: ↑Sun Sep 17, 2017 7:16 pm hi everyone i'm using freecad 0.17 and created a drawing with part and part design. When i wanted to make a drawing with techdraw, i coul only choose one part. but i need all the parts in my drawing. How is this achieved.
- waterinlaat.png (18.34 KiB) Viewed 3501 times
wandererfan was a little bit faster...robotMarvin wrote: ↑Sun Sep 17, 2017 7:16 pm hi everyone i'm using freecad 0.17 and created a drawing with part and part design. When i wanted to make a drawing with techdraw, i coul only choose one part. but i need all the parts in my drawing. How is this achieved.
You can generate tubes/flanges/washers/srews much faster by using the flamingo/fasteners-wb.
The objects a fully parametric. Installation with tools==>addon manager (after install close/restart FC)
I am wondering why I can attach the screws at the flanges from flamingo, but
getting errors on your part.
regards Thomas
- robotMarvin
Thanks everyone, for the fast reply, i tried multiview before, but i couldn't figure out how to use it. Now i tried harder, and knew it was the tool, and i figured out how to use it. I will also look into flamingo/fasteners
i also don't know, i will try tofind out later.I am wondering why I can attach the screws at the flanges from flamingo, but
- robotMarvin
flamingo works great !!
But is there a way to get more flanges, i only seem to find flanges asme-150lb and DIN-PN16. I need DIN-PN10 Maybe there is a way to download ??
Else i can always adjust the prorperties. Anyway, i m very happy with flamingo wb
Hi all
I managed to generate a view of multiple parts using the above mentioned multipart view button. But how can one select which views (side, top etc) and the scale of the view. Currently, I select all parts and then click on the multiple parts view button and it automatically gives me one view. I cannot select the view type and its scale either before or after the view has been generated. Please help.
- wandererfan
Change the Direction and/or Scale properties in the PropertyEditor.
From TechDraw_NewView.
Direction: A vector representing the viewing direction.
Scale: A view will be rendered on the page in Scale:1 ratio to the Source. (1)
ScaleType: "Document": use the Page's scale setting. "Custom": use a scale unique to this view. "Automatic": fit view to page. (1)
Front: (0,-1,0)
Top: (0,0,1)
Right: (1,0,0)
Axo: (1,1,1)
Thank You for the positive feedback.
To create your own dimensional table of flanges (or other piping object as well) you can follow the suggestion at page 3 of the tutorialPype.pdf (../Mod/flamingo/tutorials).robotMarvin wrote: ↑Tue Sep 19, 2017 8:11 pm But is there a way to get more flanges, i only seem to find flanges asme-150lb and DIN-PN16. I need DIN-PN10 Maybe there is a way to download ??
* For instance, open the file ../Mod/flamingo/tables/Flange_DIN-PN16.csv with any spreadsheet program.
* Modify the dimensions in the table. You can also add or delete rows and change the name of size-names in the first column.
* Save it in the same folder as "Flange_myRating.csv". Remember to use ";" as separators.
Now, next time you run "Insert a flange", the "myRating" option will appear in the dialog with the customized flanges dimensions.
I guess that columns names are quite self-explaining.
Obviously, must care that dimensions are consistent: for example it should not be D<d!
Oddtopus,
I wouldn't put bolts in one at a time .. See FC Forum>showcase>"Pressure vessel with piping". It took a long time to make the first draft including the time to learn FC and python. The second time it took less than 20 hours. The attached script is how I set up the flanges and bolting. Unfortunately it is in US Customary units - let me know if you want to see more.
- flange_and_bolts.txt
- (7.53 KiB) Downloaded 58 times
