FreeCAD 0.17 Crash with automated drawing generator
JMG
Postby JMG » Mon Feb 19, 2018 6:19 pm
I am working on an automated part to tech-draw drawing script and it crashes FreeCAD every time I run it.
This is the python code:
import time
import FreeCADGui
from operator import itemgetter
import random
base_name = "EDCPI_"
drawing_revision = 'R0'
author_name = "JMG"
max_label = 50
current_label = 0
# create new document
FreeCAD.newDocument("Unnamed")
FreeCAD.setActiveDocument("Unnamed")
FreeCAD.ActiveDocument=App.getDocument("Unnamed")
FreeCAD.Gui.ActiveDocument=Gui.getDocument("Unnamed")
# create dummy objects
for i in range(max_label):
    obj = FreeCAD.ActiveDocument.addObject("Part::Feature", base_name + str(current_label))
    obj.Shape = Part.makeBox(random.randint(5,30),random.randint(5,30),random.randint(5,30) )
    obj.Placement.Base.x = random.randint( -100, 100 )
    obj.Placement.Base.y = random.randint( -100, 100 )
    obj.Placement.Base.z = random.randint( -100, 100 )
    current_label += 1
current_label = 0
def doDrawingForLabel(label):
    current_label = label
    for obj in FreeCAD.ActiveDocument.Objects:
        try:
            if int( obj.Label[len(base_name):] ) == current_label:
                if obj.Shape.Volume != 0:  #check for solid
                    # create and setup page
                    draw_page = FreeCAD.ActiveDocument.addObject("TechDraw::DrawPage", obj.Label )
                    # TODO TEMPLATE IN DEPENDENCE OF BOUND BOX
                    # adjust templat
                    template = FreeCAD.ActiveDocument.addObject( 'TechDraw::DrawSVGTemplate', 'Template')
                    template.Template =  "/usr/share/freecad-daily/Mod/TechDraw/Templates/A3_Landscape_ISO7200TD.svg"
                    draw_page.Template = template
                    # fill template
                    date = time.localtime()
                    template.setEditFieldContent("FC-DATE", str(date.tm_mday) + '/' + str( date.tm_mon ) + '/' + str( date.tm_year )  )
                    template.setEditFieldContent("DRAWING_TITLE", obj.Label )
                    template.setEditFieldContent("AUTHOR_NAME", author_name )
                    template.setEditFieldContent("FC-SC", "1:1")
                    template.setEditFieldContent("PN", obj.Label )
                    template.setEditFieldContent("FC-SH", str(current_label ) + " / " + str(max_label - 1 ) )
                    template.setEditFieldContent("FC-REV", drawing_revision )
                    # number of equal parts
                    part_counter = -1
                    for p in FreeCAD.ActiveDocument.Objects:
                        if p.Label == obj.Label:
                            part_counter +=1
                    template.setEditFieldContent("SI-4", str(part_counter) + " unidades" )
                    # set selection here
                    FreeCAD.Gui.Selection.clearSelection()
                    FreeCAD.Gui.Selection.addSelection(draw_page)
                    FreeCAD.Gui.Selection.addSelection(obj)
                    # create view
                    part_view = FreeCAD.ActiveDocument.addObject( 'TechDraw::DrawViewPart', obj.Label + "_view" )
                    draw_page.addView(part_view)
                    part_view.Source = [obj]
                    # check viewpoint refered
                    bbox_bounds = obj.Shape.BoundBox.XLength, obj.Shape.BoundBox.YLength, obj.Shape.BoundBox.ZLength
                    min_idx = min( enumerate(bbox_bounds), key=itemgetter(1))[0]
                    # add sheet dimension to data template
                    template.setEditFieldContent("FreeCAD_DRAWING", "Chapa de " + str( round(bbox_bounds[min_idx]) ) + "mm en Acero St 37" )
                    view_direction = FreeCAD.Vector(0.0,0.0,0.0)
                    view_direction[min_idx] = 1.0
                    part_view.Direction = view_direction
                    FreeCAD.ActiveDocument.recompute()
                    current_label += 1
                    break
        except ValueError:
            print obj.Label
    doDrawingForLabel(i)
The code looks for objects in the document sharing the same base label and starts creating techdraw pages for each different part. I've added a small initial header which creates some dummy objects with the required naming convention to facilitate testing.
The trace FreeCAD leaves on terminal is:
FreeCAD 0.17, Libs: 0.17R13303 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
Fasteners workbench Loaded
During initialization the error "'Tubos' already exists." occurred in /home/javier/.FreeCAD/Mod/TubosWorkbench/InitGui.py
Please look into the log file for further information
not a freecad file: .STEP
not a freecad file: .STL
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f3d636e84b0]
#1  /lib/x86_64-linux-gnu/libc.so.6(strlen+0x26) [0x7f3d6373e746]
#2  0x7f3d5e84ffc3 in Shiboken::setErrorAboutWrongArguments(_object*, char const*, char const**) from /usr/lib/x86_64-linux-gnu/libshiboken-python2.7.so.1.2+0x6c3
#3  /usr/lib/python2.7/dist-packages/PySide/QtCore.so(+0x117cb9) [0x7f3d3a480cb9]
#4  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x8ad0) [0x7f3d652ae9f0]
#5  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x85c) [0x7f3d653e405c]
#6  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(+0x13e370) [0x7f3d6533a370]
#7  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7f3d6530d273]
#8  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_CallObjectWithKeywords+0x47) [0x7f3d653e3487]
#9  0x7f3d3a103d99 in PySide::SignalManager::callPythonMetaMethod(QMetaMethod const&, void**, _object*, bool) from /usr/lib/x86_64-linux-gnu/libpyside-python2.7.so.1.2+0x79
#10  /usr/lib/x86_64-linux-gnu/libpyside-python2.7.so.1.2(+0x16459) [0x7f3d3a10b459]
#11  0x7f3d641b4166 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x626
#12  /usr/lib/python2.7/dist-packages/PySide/QtCore.so(+0x1a16e3) [0x7f3d3a50a6e3]
#13  0x7f3d641b9c83 in QObject::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0xa3
#14  /usr/lib/python2.7/dist-packages/PySide/QtCore.so(+0x1a1263) [0x7f3d3a50a263]
#15  0x7f3d646ccfdc in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x8c
#16  0x7f3d646d3f16 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x2b6
#17  0x7f3d66332d94 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x54
#18  0x7f3d6419f90d in QCoreApplication::notifyInternal(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x8d
#19  /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x1bd780) [0x7f3d641d2780]
#20  /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x1ba8f1) [0x7f3d641cf8f1]
#21  /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x2a7) [0x7f3d5cdd7197]
#22  /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x4a3f0) [0x7f3d5cdd73f0]
#23  /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7f3d5cdd749c]
#24  0x7f3d641d02ae in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x7e
#25  /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272616) [0x7f3d6477a616]
#26  0x7f3d6419e18f in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x3f
#27  0x7f3d6419e4f5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x1b5
#28  0x7f3d641a44b9 in QCoreApplication::exec() from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x99
#29  0x7f3d662ebb70 in Gui::Application::runApplication() from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x15b0
#30  freecad-daily(main+0x8b4) [0x403834]
#31  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f3d636d3830]
#32  freecad-daily(_start+0x29) [0x404a79]
My FreeCAD info is:
OS: Linux Mint 18 Sarah
Version: 0.17.13303 (Git)
Build type: None
Hash: b47e011c1cc6357fa776624d371ed434989c79b1
Python version: 2.7.12
OCC version: 7.1.0
Locale: Spanish/Spain (es_ES)
If someone else can confirm this crash I'll post it to mantis.
(I placed the post here because tech-draw is the module involved, feel free to move this where it suits better)
Regards,
Javier.
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
wandererfan
Re: FreeCAD 0.17 Crash with automated drawing generator
Postby wandererfan » Tue Feb 20, 2018 1:46 am
EDIT: note that the macro will cause a crash on this machine, but only after 113 iterations vs 50 or less in the other configurations.
It doesn't crash on this machine:
OS: Ubuntu 12.04.5 LTS
Version: 0.17.13290 +5 (Git)
Build type: debug
Branch: Fixes
Hash: f07d3a177f6c47e98c79f49a834775ce06cd9c0c
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
OCC version: 7.2.0
I'll try on a different configuration tomorrow. Are you trying to run this from FreeCADCmd? I don't think that will work.
JMG
Postby JMG » Tue Feb 20, 2018 8:26 am
Nope, just plain FreeCAD, running from launch icon or terminal (freecad-daily) crash the same.
wandererfan
Postby wandererfan » Tue Feb 20, 2018 6:43 pm
Confirm crash on:
OS: Ubuntu 16.04.3 LTS
Build type: None
OCC version: 7.1.0
with what looks to be the same backtrace:
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f556e8b64b0]
#1  /lib/x86_64-linux-gnu/libc.so.6(strlen+0x26) [0x7f556e90c746]
#2  0x7f5569a4efc3 in Shiboken::setErrorAboutWrongArguments(_object*, char const*, char const**) from /usr/lib/x86_64-linux-gnu/libshiboken-python2.7.so.1.2+0x6c3
#3  /usr/lib/python2.7/dist-packages/PySide/QtCore.so(+0x117cb9) [0x7f5550f0acb9]
#4  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x8ad0) [0x7f557047c9f0]
#5  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x85c) [0x7f55705b205c]
#6  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(+0x13e370) [0x7f5570508370]
#7  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7f55704db273]
#8  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_CallObjectWithKeywords+0x47) [0x7f55705b1487]
#9  0x7f5550b94d99 in PySide::SignalManager::callPythonMetaMethod(QMetaMethod const&, void**, _object*, bool) from /usr/lib/x86_64-linux-gnu/libpyside-python2.7.so.1.2+0x79
#10  /usr/lib/x86_64-linux-gnu/libpyside-python2.7.so.1.2(+0x16459) [0x7f5550b9c459]
#11  0x7f556f382166 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x626
#12  /usr/lib/python2.7/dist-packages/PySide/QtCore.so(+0x1a16e3) [0x7f5550f946e3]
#13  0x7f556f387c83 in QObject::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0xa3
#14  /usr/lib/python2.7/dist-packages/PySide/QtCore.so(+0x1a1263) [0x7f5550f94263]
#15  0x7f556f89afdc in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x8c
#16  0x7f556f8a1f16 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x2b6
#17  0x7f5571500d94 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x54
#18  0x7f556f36d90d in QCoreApplication::notifyInternal(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x8d
#19  /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x1bd780) [0x7f556f3a0780]
#20  /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x1ba929) [0x7f556f39d929]
#21  /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x2a7) [0x7f5567fd6197]
#22  /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x4a3f0) [0x7f5567fd63f0]
#23  /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7f5567fd649c]
#24  0x7f556f39e2ae in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x7e
#25  /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272616) [0x7f556f948616]
#26  0x7f556f36c18f in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x3f
#27  0x7f556f36c4f5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x1b5
#28  0x7f556f3724b9 in QCoreApplication::exec() from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x99
#29  0x7f55714b9b70 in Gui::Application::runApplication() from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x15b0
#30  /usr/bin/freecad-daily(main+0x8b4) [0x403834]
#31  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f556e8a1830]
#32  /usr/bin/freecad-daily(_start+0x29) [0x404a79]
But I don't recognize much in the trace. :(
wandererfan
Postby wandererfan » Tue Feb 20, 2018 7:12 pm
FWIW, the crash happens after the macro completes
iteration: 47
iteration: 48
iteration: 49
drawing loop ended - exiting macro
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f9af6eee4b0]
#1  0x7f9af20869e9 in Shiboken::setErrorAboutWrongArguments(_object*, char const*, char const**) from /usr/lib/x86_64-linux-gnu/libshiboken-python2.7.so.1.2+0xe9
#2  /usr/lib/python2.7/dist-packages/PySide/QtCore.so(+0x117cb9) [0x7f9ad9542cb9]
#3  /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x8ad0) [0x7f9af8ab49f0]
JMG
Postby JMG » Tue Feb 20, 2018 8:31 pm
I confirm that too.
As an experiment, I have set the script to save the freecad document at each iteration. When it crashes, I re-open the document and run it from last iteration saved. This way I succesfully converted all the parts to drawings this way, and it makes me think that the crash is not dependent on the part being draw.
wandererfan
Postby wandererfan » Thu Feb 22, 2018 12:33 am
just adding a gdb backtrace:
[Thread 0x7fffc9b7e700 (LWP 13556) exited]
Thread 1 "FreeCAD" received signal SIGSEGV, Segmentation fault.
0x00007ffff3b18746 in strlen () from /lib/x86_64-linux-gnu/libc.so.6
(gdb) bt
#0  0x00007ffff3b18746 in strlen () from /lib/x86_64-linux-gnu/libc.so.6
#1  0x00007fffeec5afc3 in std::char_traits<char>::length (__s=0x0)
    at /usr/include/c++/5/bits/char_traits.h:267
#2  std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::assign (__s=0x0, this=0x7fffffffbf90)
    at /usr/include/c++/5/bits/basic_string.h:1166
#3  std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::operator= (__s=0x0, this=0x7fffffffbf90)
    at /usr/include/c++/5/bits/basic_string.h:559
#4  Shiboken::setErrorAboutWrongArguments (args=<optimized out>,
    funcName=0x7fffd5dad5f0 "PySide.QtCore.QObject.blockSignals",
    cppOverloads=0x7fffffffc0f0)
    at /build/shiboken-0qY8oQ/shiboken-1.2.2/libshiboken/basewrapper.cpp:529
#5  0x00007fffd5cb7cb9 in ?? ()
   from /usr/lib/python2.7/dist-packages/PySide/QtCore.so
#6  0x00007ffff56889f0 in call_function (oparg=<optimized out>,
    pp_stack=0x7fffffffc1e0) at ../Python/ceval.c:4338
#7  PyEval_EvalFrameEx (f=<optimized out>, throwflag=<optimized out>)
    at ../Python/ceval.c:2987
#8  0x00007ffff57be05c in PyEval_EvalCodeEx (co=<optimized out>,
    globals=<optimized out>, locals=<optimized out>, args=<optimized out>,
    argcount=0, kws=<optimized out>, kwcount=0, defs=0x0, defcount=0,
    closure=0x0) at ../Python/ceval.c:3582
---Type <return> to continue, or q <return> to quit---
#9  0x00007ffff5714370 in function_call.lto_priv.348 (
    func=<function at remote 0x7fffcd086488>, arg=(), kw=0x0)
    at ../Objects/funcobject.c:523
#10 0x00007ffff56e7273 in PyObject_Call (
    func=<function at remote 0x7fffcd086488>, arg=<optimized out>,
    kw=<optimized out>) at ../Objects/abstract.c:2546
#11 0x00007ffff57bd487 in PyEval_CallObjectWithKeywords (
    func=<function at remote 0x7fffcd086488>, arg=(), kw=<optimized out>)
    at ../Python/ceval.c:4219
#12 0x00007fffd5941d99 in PySide::SignalManager::callPythonMetaMethod(QMetaMethod const&, void**, _object*, bool) ()
#13 0x00007fffd5949459 in ?? ()
#14 0x00007ffff458e166 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#15 0x00007fffd5d416e3 in ?? ()
#16 0x00007ffff4593c83 in QObject::event(QEvent*) ()
#17 0x00007fffd5d41263 in ?? ()
#18 0x00007ffff4aa6fdc in QApplicationPrivate::notify_helper(QObject*, QEvent*)
    () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#19 0x00007ffff4aadf16 in QApplication::notify(QObject*, QEvent*) ()
#20 0x00007ffff716b36a in Gui::GUIApplication::notify (this=0x7fffffffd6b0,
    receiver=0xf56430, event=0x7fffffffcb80)
    at /home/mruser/Source/FreeCAD-src/src/Gui/GuiApplication.cpp:91
#21 0x00007ffff457990d in QCoreApplication::notifyInternal(QObject*, QEvent*)
#22 0x00007ffff45ac780 in ?? () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#23 0x00007ffff45a98f1 in ?? () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#24 0x00007fffed410197 in g_main_context_dispatch ()
   from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#25 0x00007fffed4103f0 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#26 0x00007fffed41049c in g_main_context_iteration ()
#27 0x00007ffff45aa2ae in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#28 0x00007ffff4b54616 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#29 0x00007ffff457818f in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#30 0x00007ffff45784f5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#31 0x00007ffff457e4b9 in QCoreApplication::exec() ()
#32 0x00007ffff70f9e91 in Gui::Application::runApplication ()
    at /home/mruser/Source/FreeCAD-src/src/Gui/Application.cpp:1902
#33 0x00000000004090af in main (argc=1, argv=0x7fffffffdf78)
    at /home/mruser/Source/FreeCAD-src/src/Main/MainGui.cpp:261
(gdb)
(gdb)
(gdb)
wandererfan
Postby wandererfan » Thu Feb 22, 2018 12:36 am
Javier, you better make a ticket. I haven't found an answer yet. Gracias.
JMG
Postby JMG » Thu Feb 22, 2018 8:47 am
