override dimension value
easyw-fc
Postby easyw-fc » Sat Mar 10, 2018 2:02 pm
I have searched at the forum but I couldn't find any topic on this...
Is it possible to change a dimension value with a user new value?
I know this is not the best practice but I would need to write an approximated value to some of my design quote.
Thx
Maurice
miro
Re: override dimension value
Postby miro » Sat Mar 10, 2018 3:59 pm
Doesn't the Format property do what you need? You can specify the number of decimal places to round up to.
wandererfan
Postby wandererfan » Sat Mar 10, 2018 5:24 pm
On the list, but didn't make it into 0.17. https://www.forum.freecadweb.org/viewto ... 35&t=26559
easyw-fc
Postby easyw-fc » Sat Mar 10, 2018 9:12 pm
a quick solution could be to just add the ability to hide the value, leaving the arrow in place.. then it is possible to add an annotation near the arrow of the dimension.
ATM it can be done with a trick, adding an image to cover the value and then add an annotation over the image...
In my case it wouldn't help... I would have 7.9 instead of 8.0 desired
And moreover it seems that the format notation is not working for me.. any value will just let the result unchanged... it seems it uses only the units from the number of decimals coming from the preference menu...
Version: 0.17.13387 (Git)
Hash: c5f4079252b11e3c54cd603be7d3697fa9f9d922
Python version: 2.7.14
OCC version: 7.1.0
wandererfan
Postby wandererfan » Sun Mar 11, 2018 12:20 am
Is preference "Use Global Decimals" set true? The format spec will only override if you're using alternate decimals.
easyw-fc
Postby easyw-fc » Sun Mar 11, 2018 4:31 pm
you are right, I didn't know about this setting...
Now it is working as described above.
mfasano
Postby mfasano » Fri Jun 08, 2018 1:44 pm
One reason to be able to put something arbitrary in a dimension is if you have models of the same thing in different sizes. I have seen manuals with drawings of dimensions A, B,C and a table to show the dimensions of each model.
wandererfan
Postby wandererfan » Sat Jun 09, 2018 5:20 pm
This has been available for a little while. From TechDraw_Dimension_Length:
magnet
Postby magnet » Sat Jun 30, 2018 4:19 pm
Available from which version?
Postby chrisb » Sat Jun 30, 2018 8:09 pm
Hey man, just install the most recent and you have it.
I have it in
OS: Mac OS X
Version: 0.18.13976 (Git)
Branch: (HEAD detached at fae0de5)
Hash: fae0de58581694157a97d567c151bdce75d387dc
Python version: 2.7.15
Qt version: 5.11.0
OCC version: 7.2.0
