Four points on the circles
How to get four points in circles? The four points of intersection with the axes, instead of only one.
Re: Four points on the circles
Using 4 arcs seems to work, but might not be very convenient if you have to redraw all your sketches...
Cheers-
Thank you!
- wandererfan
You can make the arc center marker bigger with "VIEW CenterScale: Circular arc center mark size adjustment, if enabled.". The cross will intersect the circle, but no extra vertices will be created.renatorivo wrote: ↑Fri Apr 27, 2018 9:31 pm How to get four points in circles? The four points of intersection with the axes, instead of only one.
