Dxf Export of Dimension
For any dimension, we need to write block of every dimension shape [say lines, dimension value as text] in block section.
Then you have refer the block number in dimension entity details. This is required to open in directly autocad.
see dxf attached exported from freecad with above change.
This is just for information.
- dim.dxf
- (2.92 KiB) Downloaded 87 times
- wandererfan
Re: Dxf Export of Dimension
Thanks for the file. Back to the Dxf spec book.jaisejames wrote: ↑Thu May 24, 2018 7:02 am For any dimension, we need to write block of every dimension shape [say lines, dimension value as text] in block section.
Currently exported dxf from techdraw syntax error coming.
Pls note that Group code should be 3 digit. In case 2, it should be one space followed by code. In case one digit, it should be two space followed by code. See the below code for reference.
100
AcDbDimension
2
*DIMENSION
10
0.446097594071
20
-0.277299734401
30
0.0
11
-0.699780139756
21
-0.274470368969
31
0.0
70
1
3
- wandererfan
What version of dxf is your program (autocad?) trying to import? The library we are using for export seems to be making AC1009/R12. The thing about 3 positions for group codes is a "relatively recent" change.jaisejames wrote: ↑Tue May 29, 2018 7:47 am Currently exported dxf from techdraw syntax error coming.
What FreeCAD are you running? There have been a few changes to the Dxf export code in the last week. Maybe one of the changes has caused a regression?
LibreCAD seems quite happy importing as is and I don't have any other Dxf programs.
easyw-fc wrote: Are you still getting good results with Dxf export?
if you re-export by LibreCAD the file as 'dxf R12' what you have produced as FX dxf, you get a messy dxf also if you reload it in librecad...wandererfan wrote: ↑Tue May 29, 2018 12:26 pm LibreCAD seems quite happy importing as is and I don't have any other Dxf programs.easyw-fc wrote: Are you still getting good results with Dxf export?
I think the header part or the quoting part is in some way wrong...
If you also re-import in FC a dxf generated by FC with dimensions you get an empty document (I'm testing with legacy importer)
My FC testing release:
Version: 0.18.13824 (Git)
Hash: 73d597710fe15f1ee3453bf75c0f4f95c309764a
Python version: 2.7.14
OCC version: 7.2.0
First I tested LibreCad, But it is crashingwandererfan wrote: ↑Tue May 29, 2018 12:26 pmWhat version of dxf is your program (autocad?) trying to import? The library we are using for export seems to be making AC1009/R12. The thing about 3 positions for group codes is a "relatively recent" change.jaisejames wrote: ↑Tue May 29, 2018 7:47 am Currently exported dxf from techdraw syntax error coming.
Version: 2.2.0-rc1
Compiler: GNU GCC 4.9.1
Compiled on: Feb 16 2018
Qt Version: 5.4.1
Boost Version: 1.53.0
System: Windows 7
Then I used Autocad true viewer 2019, it is opening as blank & some error message show.
One thing I noticed, In poly-line vertices numbers, it written strange value.[-1.#QNAN]
100
AcDbPolyline
90
-1.#QNAN
- 12.dxf
- (6 KiB) Downloaded 55 times
We can a comment in file first like this for traceability.
999
Drawing created by FreeCAD : 0.18.13824 (Git)
- wandererfan
NAN is c++ shorthand for "Not A Number". should never see this.
Any chance you can post your FCStd file and the list of error messages from the viewer?
See the attached file with vertex issue
- 13.dxf
- (6.65 KiB) Downloaded 61 times
- techdraw dxf.FCStd
- (21.83 KiB) Downloaded 54 times
