Try this one. It looks ok in Draftsight.jaisejames wrote: ↑Fri Jun 08, 2018 11:58 am This is with dimension. Please compare code difference [ignore position value diff]
Some extra code 71 not required & some forgot to insert code 70.
Some dim arrow is flipped in export see screenshot.
Dxf Export of Dimension
- wandererfan
Re: Dxf Export of Dimension
- dimCompatTest.dxf
- (74.1 KiB) Downloaded 46 times
working perfectly.wandererfan wrote: ↑Sat Jun 09, 2018 5:05 pmPlease try the attached file for ACAD compatibility. Thanks.jaisejames wrote: ↑Fri Jun 08, 2018 11:35 am I have made some modification in dxf and now directly opening autocad.
Could you please compare two[original & modified dxf files] & insert those changes. Change are in $DWGCODEPAGE[removed], VPORT[some code removed] & DIMSTYLE[added some code]. No Other changes.
code 71 not required. [see attached file for comparison]wandererfan wrote: ↑Sun Jun 10, 2018 12:17 amTry this one. It looks ok in Draftsight.jaisejames wrote: ↑Fri Jun 08, 2018 11:58 am This is with dimension. Please compare code difference [ignore position value diff]
diameter, radius text position is not correct [see screenshot].
- autocad_view_dim2.jpg (15.88 KiB) Viewed 1461 times
- dimCompatTest_modified.dxf
- (74.08 KiB) Downloaded 42 times
One suggestion, we will make each view a block with actual size & then scale it on block insertion.
So somebody require actual one, just insert block.
- wandererfan
getting closer. code 71 on Dims is from later version of Dxf, will remove.jaisejames wrote: ↑Mon Jun 11, 2018 5:38 am code 71 not required. [see attached file for comparison]
Not sure why text pos is wrong. Looks like same code as linear/angular.
Not sure what this means, actually. My dxf knowledge is just what I've picked up fixing the existing code. Can you post a sample?jaisejames wrote: One suggestion, we will make each view a block with actual size & then scale it on block insertion.
Thanks for testing.
I just exported one cube to dxf with 3 views. see attached file from our legacy exporter as block [shape2d to block].
I just modified first inserted view with 41 & 42 to scale the block in x & y
INSERT 66 (Attributes follow flag -optional 0), 2 (Block name),
10, 20, 30 (insertion point), 41 (X- scale factor
-optional 1), 42 (Y scale factor -optional 1), 43 (Z-
scale factor -optional 1), 50 (rotation angle -optional
0), 70 and 71 (column and row counts -optional 1), 44 and
45 (column and row spacing -optional 0).
- 12.dxf
- (2.47 KiB) Downloaded 38 times
- wandererfan
Please check this file for diameter/radius text position. Thanks.jaisejames wrote: ↑Mon Jun 11, 2018 5:38 am diameter, radius text position is not correct [see screenshot].
- dimCompatTestDiaRad.dxf
- (75.13 KiB) Downloaded 45 times
See attached freecad file. If techdraw page dxf exported, position of one view changes.
- 11.png (16.49 KiB) Viewed 1398 times
- boolean.FCStd
- (385.73 KiB) Downloaded 42 times
Everything OK. see attached screenshot. But diameter symbol is showing some strange values & angle arrow both in one side.wandererfan wrote: ↑Tue Jun 12, 2018 12:21 pmPlease check this file for diameter/radius text position. Thanks.jaisejames wrote: ↑Mon Jun 11, 2018 5:38 am diameter, radius text position is not correct [see screenshot].
- dim2.png (32.74 KiB) Viewed 1396 times
- wandererfan
Is your "Diameter symbol" in Preferences set to a unicode character? Dxf R12 only understands ASCII (and somethings called MIF and CIF). If you change your preference to "%%c" it will show as Ø in Draftsight and probably ACAD - but it will show as "%%c" in FC.jaisejames wrote: ↑Tue Jun 12, 2018 12:50 pm Everything OK. see attached screenshot. But diameter symbol is showing some strange values & angle arrow both in one side.
The arrow problem is a 1 character typo in the source.
