I cannot insert DraftText to TechDraw page.
I think, it maybe from Draft Annotation rename to "DraftText".
Version: 0.18.13870 (Git)
Hash: f0964a9c052ee666631cd9caec1655790964ecb6
Python version: 2.7.14
OCC version: 7.2.0
[Solved]Cannot insert DraftText to TechDraw page.
Re: Cannot insert DraftText to TechDraw page.
Indeed, thanks for reporting. This is now fixed in git commit 93eb05b1b
Thank you very much.yorik wrote: ↑Fri Jun 01, 2018 2:06 pm Indeed, thanks for reporting. This is now fixed in git commit 93eb05b1b
Re: [Solved]Cannot insert DraftText to TechDraw page.
The first image use inserts draft button.
The second image uses the macro to manage each piece of Draft Object by function Draft.getSVG() to generate each SVG's element with different line type and line width of grids group.
#-*- coding:utf8 -*-
import FreeCADGui
import Draft
def TestGetSVG():
import Draft
sel = FreeCADGui.Selection.getSelection()[0]
for obj in sel.OutList:
Msg('%s , %s '%( obj.Label , Draft.getType(obj) ) )
Msg(', %s'%(Draft.getSVG(obj , scale=0.01 ,linestyle='5,2,1,2' ) ))
Msg('\n')
SVGHead = '''<svg
xmlns="http://www.w3.org/2000/svg" version="1.1"
xmlns:freecad="http://www.freecadweb.org/wiki/index.php?title=Svg_Namespace">
SVGTail='</svg>'
def TestGetSVG2():
svg = ''
if Draft.getType(obj) in ['Wire' ]:
if obj.Label[:4]=='Grid':
svg += Draft.getSVG(obj , scale=0.01 , linestyle='5,1.5,1,1.5' ,
linewidth=0.18, techdraw=True)
else:
linewidth=0.35, techdraw=True)
elif Draft.getType(obj) in ['Dimension' ]:
svg += Draft.getSVG(obj , scale=0.01,linewidth=0.25,techdraw=True )
elif Draft.getType(obj) in [ 'Circle' , 'Ellipse' ,'Rectangle' , 'Polygon' ]:
elif Draft.getType(obj) in [ 'ShapeString' ,'DraftText']:
svg += Draft.getSVG(obj , scale=0.01, fontsize=3, linewidth=0, techdraw=True )
#Msg('%s\n'%svg)
svg = SVGHead + svg + SVGTail
symbol = FreeCAD.ActiveDocument.addObject('TechDraw::DrawViewSymbol','Symbol')
symbol.Symbol = svg
symbol.Scale = 1/100.0*3.78
FreeCAD.ActiveDocument.Page.addView(symbol)
FreeCAD.ActiveDocument.recompute()
if __name__=='__main__':
#TestGetSVG()
TestGetSVG2()
Draft.getSVG(sel,scale=0.01 , techdraw=True)
Draft.getType(sel)
def getSVG(obj,scale=1,linewidth=0.35,
fontsize=12,fillstyle="shape color",
direction=None,linestyle=None,
color=None,linespacing=None,
techdraw=False,rotation=0):
isinstance(sel,Part.Shape)
Nice! It made me notice and fix a bug, draft texts were not appearing on file load...
