R14 ACAD Compatibilty Testing
wandererfan
Postby wandererfan » Wed Jun 27, 2018 3:54 pm
I have no Autodesk s/w available. Would somebody be so kind as to check the attached files in ACAD and report any errors received?
The files work in DraftSight, LibreCad and QCad, but as we all know that doesn't mean they work in ACAD.
Thanks,
wf
exportBasicShapesR14.dxf
(6.1 KiB) Downloaded 31 times
exportBasicShapesR12.dxf
(13.42 KiB) Downloaded 28 times
markko martin
Re: R14 ACAD Compatibilty Testing
Postby markko martin » Wed Jun 27, 2018 4:21 pm
Hi wanderefan.
ZWCAD 2014 opens exportBasicShapesR12 and all is perfect.
Autocad LT 2009 opens exportBasicShapesR12. Text is visible but I cant't edit it.
exportBasicShapesR14 doesn't work with Autocad LT 2009.
default item ACAD is missing into SymbolTable APPID.
Input DXF is invalid.
Ps: sorry for my english ;)
Loris
easyw-fc
Postby easyw-fc » Wed Jun 27, 2018 6:57 pm
Testing with DWG TrueView for win of Autodesk:
exportBasicShapesR12.dxf -> viewable as in LibreCAD
exportBasicShapesR14.dxf -> it doesn't open in DWGTV
PS imported in LC and exported as R14, the result in DWGTV is as it should.
Thx for developing this feature :D
jaisejames
Postby jaisejames » Thu Jun 28, 2018 4:51 am
kindly check modified file opening file opening in ACAD.
some warning with Handle numbering so it need to correct accordingly & handle number require to be hexa.
exportBasicShapesR14_modified.dxf
(6.34 KiB) Downloaded 22 times
Opus
Postby Opus » Thu Jun 28, 2018 6:43 am
Tested in Autodesk TrueView :
  • exportBasicShapesR14.dxf : error
Missing Default entry ACAD in SymbolTable:APPID
Invalid or incomplete DXF input -- drawing discarded.
  • exportBasicShapesR12.dxf : it works !
markko martin
Postby markko martin » Thu Jun 28, 2018 10:24 am
Autocad LT 2009:
exportBasicShapesR14_modified.dxf: it works.
I don't see the right font but no problem..
Loris
wandererfan
Postby wandererfan » Thu Jun 28, 2018 12:28 pm
Thanks to all for the testing help. I'll publish improved versions soon.
wf
Walgri
Postby Walgri » Thu Jun 28, 2018 12:50 pm
both R12 and latest R14 look ok on Microstation v8i SS3.
wandererfan
Postby wandererfan » Thu Jun 28, 2018 7:34 pm
Could we try again? Thanks.
exportBasicShapesR14v2spline.dxf
(5.15 KiB) Downloaded 15 times
exportBasicShapesR14v2poly.dxf
(6.23 KiB) Downloaded 14 times
exportBasicShapesR12v2.dxf
(7.89 KiB) Downloaded 18 times
easyw-fc
Postby easyw-fc » Thu Jun 28, 2018 7:42 pm
DWGTV:
Missing Default entry *Model_Space in SymbolTable:BLOCK_RECORD
the viewer just get stucked.
