R14 ACAD Compatibilty Testing
easyw-fc
Re: R14 ACAD Compatibilty Testing
Post by easyw-fc »
NormandC wrote: Sun Jul 01, 2018 9:01 pm This is undesirable on Linux. You're adding another method of installing besides the operating system's method. I hate it, one of the reasons being pip is CLI only. And it's almost certain to create trouble with some Linux distributions. Linux distros don't look kindly to bundling third-party libraries either.
So ezdxf would need to be packaged in all Linux distros that provide FreeCAD. :|
Oh, and then there's the fact that ezdxf is dropping Python 2 support. https://ezdxf.mozman.at/dropping-python2-support.html
The FC dxf library is already installed as an external lib by FC application, because of License issues.
May be we could manage to handle ezdxf in the same way in which the dxf lib is downloaded and installed now...
ezdxf is a mature lib for dxf that could add value to both importer and exporter.
With a minor option, still valueable, ezdxf lib can be use as reference for the I/O coding.
jaisejames
Post by jaisejames »
wandererfan wrote: Sun Jul 01, 2018 12:31 am !@##@$#$%%!!!
It seems that inside dictionary handle number are different from other.
https://stackoverflow.com/questions/402 ... al-dxf-r13
see attached corrected file
outR14splinev6_mod.dxf
(5.34 KiB) Downloaded 55 times
jaisejames
for R12, 73 & 40 code missing in Ltype
jaisejames
[/quote]
outR12v6_mod.dxf
(7.88 KiB) Downloaded 37 times
