R14 ACAD Compatibilty Testing
- wandererfan
Re: R14 ACAD Compatibilty Testing
My bad. Had $MODEL_SPACE instead of *MODEL_SPACE.
- exportBasicShapesR14v3spline.dxf
- (5.15 KiB) Downloaded 36 times
- exportBasicShapesR14v3poly.dxf
- (6.23 KiB) Downloaded 40 times
- exportBasicShapesR12v3.dxf
- (7.89 KiB) Downloaded 37 times
The following error was encountered while reading
in TEXT starting at line 1024:
Unexpected DXF group code: 73
Invalid or incomplete DXF input -- drawing discarded.
in TEXT starting at line 866:
Table name missing on line 62.
Press ENTER to continue:
Regenerating model.
for spline & poly [attached corrected file]
73 code in text is not supported.
DICTIONARY is not available.
for basic shape
extra table line
dimstyle added 3, 4,5,6,7 codes
for basic shape
extra table line
- exportBasicShapesR14v3spline_mod.dxf
- (5.3 KiB) Downloaded 37 times
- exportBasicShapesR14v3poly_mod.dxf
- (6.38 KiB) Downloaded 72 times
- exportBasicShapesR12v3_mod.dxf
- (7.9 KiB) Downloaded 56 times
- wandererfan
If I could prevail upon your patience once again, here are new versions. Thanks again.
- outR14splinev5.dxf
- (5.34 KiB) Downloaded 39 times
- outR14polyv5.dxf
- (6.43 KiB) Downloaded 39 times
- outR12v5.dxf
- (7.9 KiB) Downloaded 37 times
I cannot open none of them in DWGTV nor in LibreCADwandererfan wrote: ↑Sat Jun 30, 2018 8:14 pm If I could prevail upon your patience once again, here are new versions. Thanks again.
outR14splinev5.dxf
outR12v5.dxf
outR14polyv5.dxf
- wandererfan
- outR14splinev6.dxf
- (5.34 KiB) Downloaded 41 times
- outR14polyv6.dxf
- (6.42 KiB) Downloaded 40 times
- outR12v6.dxf
- (7.87 KiB) Downloaded 42 times
All three files open without a hitch in LibreCAD v2.1.2 and QCad 3.15.3.
I'm at home so I can't test with DWG TrueView.
- wandererfan
When I have my act together , I test against DraftSight, LibreCad and QCad. But we've certainly had cases where a file passed all three, then crashed and burned in Autodesk s/w. So, if you're not too busy on Tuesday , a run through DWG TrueView would be great, thanks.
I can open all 3 in LC, but unfortunately I'm not able to load the 3 files in DWGTV.
ATM the exporting is working well for LibreCAD also with Bsplines ...
You may consider to use a python library to export your entities to DXF.
http://ezdxf.readthedocs.io/en/latest/t ... wings.html
The following examples are generating a Line and a BSpline file that can be displayed in DWGTV.
import ezdxf
dwg = ezdxf.new('R2010') # create a new DXF R2010 drawing, official DXF version name: 'AC1024'
msp = dwg.modelspace() # add new entities to the model space
msp.add_line((0, 0), (10, 0)) # add a LINE entity
dwg.saveas('line.dxf')
import ezdxf
dwg = ezdxf.new('AC1015') # splines requires the DXF R2000 format or later
fit_points = [(0, 0, 0), (750, 500, 0), (1750, 500, 0), (2250, 1250, 0)]
msp.add_spline(fit_points)
dwg.saveas("simple_spline.dxf")
http://ezdxf.readthedocs.io/en/latest/r12writer.html
http://ezdxf.readthedocs.io/en/latest/i ... f-versions
from random import random
from ezdxf.r12writer import r12writer
with r12writer("quick_and_dirty_dxf_r12.dxf") as dxf:
dxf.add_line((0, 0), (17, 23))
dxf.add_circle((0, 0), radius=2)
dxf.add_arc((0, 0), radius=3, start=0, end=175)
dxf.add_solid([(0, 0), (1, 0), (0, 1), (1, 1)])
dxf.add_point((1.5, 1.5))
dxf.add_polyline([(5, 5), (7, 3), (7, 6)]) # 2d polyline
dxf.add_polyline([(4, 3, 2), (8, 5, 0), (2, 4, 9)]) # 3d polyline
dxf.add_text("test the text entity", align="MIDDLE_CENTER")
May be you can handle your entities and pass those to this lib for the exporting...
The library can be installed with pip and could be deployed with the FC installer.
- quick_and_dirty_dxf_r12.dxf
- (793 Bytes) Downloaded 35 times
- line.dxf
- (20.29 KiB) Downloaded 32 times
- simple_spline.dxf
- (18.95 KiB) Downloaded 39 times
This is undesirable on Linux. You're adding another method of installing besides the operating system's method. I hate it, one of the reasons being pip is CLI only. And it's almost certain to create trouble with some Linux distributions. Linux distros don't look kindly to bundling third-party libraries either.
So ezdxf would need to be packaged in all Linux distros that provide FreeCAD.
Oh, and then there's the fact that ezdxf is dropping Python 2 support. https://ezdxf.mozman.at/dropping-python2-support.html
