Dimension lines do not look good, it is missing a part of the beginning and the end.
The phenomenon occurs when I started using 0.18
# OS: Windows 7
# Word size of OS: 64-bit
# Word size of FreeCAD: 64-bit
# Version: 0.18.14090 (Git)
# Build type: Release
# Branch: master
# Hash: a7c8a4677f480f8733e700c3bd2cabc579e3e061
# Python version: 2.7.14
# Qt version: 4.8.7
# Coin version: 4.0.0a
# OCC version: 7.2.0
# Locale: Swedish/Sweden (sv_SE)
# OS: Windows 7
# Version: 0.17.13510 +12 (Git)
# Branch:
# Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
# Qt version: 4.8.7
[Solved] Dimension lines do not look good
- wandererfan
Re: Dimension lines do not look good
There is still a bit left at the arrow.
Sometimes it will be as before and sometimes as the new one, and sometimes it will be a mixture of both, that is, on one hand, the new and the other, according to the old one. I do not understand why and I think it looks like crap.
However, it would be better if you could specify the length of the thumb space at the beginning and end as well as the length of the arrow when it is out of the measurement line. both in prefereces and as property.
oh wow, i noticed now that this is implemented! nice work, thanks a lot!
I think the arrowhead not intersecting the extension line is quite nonstandard. The "relaxed" behavior referenced above is fine, but it looks as if the end result of the modification goes too far in "relaxing".
Gene
Gene
- wandererfan
Yes, that's an error. There's a PR in the Q to correct it.
- wandererfan
This should be fixed by git commit a077a6d1af.
Problem solved!
Now it looks relaxed.
Thanks!
OS: Windows 7
Version: 0.18.14111 (Git)
Hash: 548f63fd0eb554bb0fe5b23c1970de5fe05e3001
OCC version: 7.2.0
