I'm pretty sure TechDraw::findShapeOutline previously included holes but now it seems it only returns the outer contour of a shape.
Using the following face as input the result is a square wire. Is this intended behaviour?
[solved]: [NO] Change in TechDraw::findShapeOutline ?
Re: Change in TechDraw::findShapeOutline ?
No problem here.
OS: Ubuntu 16.04.5 LTS
Version: 0.18.14183 (Git)
Build type: None
Hash: 8ef330d19ab4aa0cfd6b9a6d41d51eed30620707
Python version: 2.7.12
Build type: None
- Bildschirmfoto 2018-07-30 um 10.29.08.png (16.81 KiB) Viewed 578 times
- wandererfan
GitHub says that code hasn't been changed for 2 years, and the definition says:
add_varargs_method("findShapeOutline",&Module::findShapeOutline,
"wire = findShapeOutline(shape,scale,direction) -- Project shape in direction and find outer wire of result."
You could try projecting the shape yourself and using
add_varargs_method("edgeWalker",&Module::edgeWalker,
"[wires] = edgeWalker(edgePile,inclBiggest) -- Planar graph traversal finds wires in edge pile."
Yeah - I had checked and that's what confused me here. As it turns out, the change is not in TechDraw, the change is in our use of TechDraw. I added invocation a month ago to work around a deficiency in PathArea - and neglected to test support for holeswandererfan wrote: ↑Mon Jul 30, 2018 12:46 pm GitHub says that code hasn't been changed for 2 years, and the definition says:
Sorry for the noise.
