Over/Under Tolerances
wandererfan
Postby wandererfan » Wed Oct 03, 2018 1:46 pm
I've lost track, but somebody requested over/under tolerances on Dimensions using superscripts and subscripts. This was added ingit commit d2c2b35b6c
NormandC
Re: Over/Under Tolerances
Postby NormandC » Thu Oct 04, 2018 4:02 am
Great, TechDraw is coming along quite nicely! Thanks for your work. :)
jouke
Postby jouke » Sun Jan 27, 2019 7:23 pm
This is great. However I can not find how to get double digits. When I try it an under or over tolerance of 0.01 becomes 0.0
Jouke
Postby chrisb » Sun Jan 27, 2019 7:48 pm
Did you set the precision in the TechDraw preferences?
jouke
Postby jouke » Mon Jan 28, 2019 1:43 pm
I didn't ... sorry
reox
Postby reox » Tue Jan 29, 2019 8:10 am
very nice! thank you! 8-)
jouke
Postby jouke » Tue Feb 12, 2019 11:42 am
This works nicely but I think there could be an improvement.
I need double decimal precision for only one drawing in 20 or so. If I set the precision in the general preferences, I have to retouch all the dimensions in all the other drawings. It would be brilliant if we could set precision per drawing or have the possibility to set the precision for over/under tolerances per case.
What do you think ?
Jouke
Jee-Bee
Postby Jee-Bee » Tue Feb 12, 2019 12:39 pm
Yes last one sounds good. Creo knows that principle too.
default all tolerance follow the precision of the main dimension. but in some cases i want a higher precision and am i able to set this.
reox
Postby reox » Tue Feb 12, 2019 6:23 pm
I noticed something else too:
If you have something like 20.42 + 0.02 - 0.001 you are required to use 3 decimal places, otherwise it is not shown. But the %g formatter (https://forum.freecadweb.org/viewtopic. ... er#p198359) does not work here and displays 20.420 +0.020 - 0.001
Not sure why it does not work anymore here?
OS: Debian GNU/Linux buster/sid
Version: 0.18.15917 (Git)
Hash: 2ac0851d4cffa351ca8da06779e14b7f9be2173d
Python version: 2.7.15+
Qt version: 5.11.3
Locale: German/Austria (de_AT)
wandererfan
Postby wandererfan » Wed Feb 13, 2019 2:11 am
%.g seems to work here (on the Dimension value, it isn't implemented for the tolerance values). Check your preferences?
If you post the file I'll dig deeper.
