Over/Under Tolerances
reox
Re: Over/Under Tolerances
Postby reox » Fri Feb 15, 2019 4:00 pm
It looks like, that no formatter works for me. WIth tolerances and without
OS: Debian GNU/Linux buster/sid
Version: 0.18.15976 (Git)
Hash: 21353779d9f53cdf143e66dba0bcb593f5d9de00
Python version: 2.7.15+
Qt version: 5.11.3
Locale: German/Austria (de_AT)
g_formatter.FCStd
(9.85 KiB) Downloaded 3 times
NormandC
Postby NormandC » Fri Feb 15, 2019 6:00 pm
Qt version: 5.11.3
What is that version? The current revision number is 15884 as can be seen on the Github repo (it's the total amount of commits) https://github.com/FreeCAD/FreeCAD
Your FreeCAD info should include a branch info right underneath the Build type, it does not.
Before saying that it doesn't work for you, maybe you should check by compiling the actual master branch, rather than some unknown and undocumented branch that may not track all commits in master.
FYI here's my own FC info from last night.
NormandC wrote:
Fri Feb 15, 2019 3:31 am
OS: Ubuntu 18.04.2 LTS
Version: 0.18.15883 (Git)
Build type: Unknown
Hash: 60f91fbef22e465386b9dc741c71d5c3103609f0
Python version: 3.6.7
Qt version: 5.9.5
Locale: French/Canada (fr_CA)
And I just noticed that I forgot to set my Build setting to Release when I compiled...
wandererfan
Postby wandererfan » Fri Feb 15, 2019 7:56 pm
Looks ok here:
with
OS: Linux Mint 19
Build type: debug
Branch: Foreground
Qt version: 5.9.5
reox
Postby reox » Sat Feb 16, 2019 1:14 pm
Qt version: 5.11.3
The current rev should be something like:
$ git rev-list --all --count
15988
So 15976 looks OK for me...
This is a build of freecad-daily against master using debian sid using this version:
https://github.com/FreeCAD/FreeCAD/comm ... 93f5d9de00
(as the hash suggest)
The branch info is not included, as I had a typo in the script generating Version.h - thanks for seeing this!
Btw if you want to build such stuff, here is the script: https://gist.github.com/reox/522922a1a6 ... edd484f48f
Looks ok here:
thanks for testing! So either my build is crooked or my configuration... I'll investigate!
reox
Postby reox » Sat Feb 16, 2019 1:18 pm
:roll: ok found the issue: I had "use global decimals" active. This seems to overwrite the formatter. Is that correct?
wandererfan
Postby wandererfan » Sat Feb 16, 2019 2:20 pm
Yes. If "use global decimals" is selected, the format string is ignored.
NormandC
Postby NormandC » Sat Feb 16, 2019 5:20 pm
15988
No, it's wrong. This is not how the revision number is counted. Again, have a look at how Github lists it as of right this instant:
So your value of 15976 exceeds the amount of commits.
The information listed in the About FreeCAD menu is extracted from the /src/Build/Version.h file that is generated by the CMake configuration. In the source code, /src/Build/CMakeLists.txt executes /src/Tools/SubWCRev.py.
After pulling from master in my code folder and running cmake in my build folder right this instant, this is what my Version.h file looks like:
// Version Number
#define FCVersionMajor "0"
#define FCVersionMinor "18"
#define FCVersionName  "Vulcan"
// test: $Format:Hash (%H), Date: %ci$
#define FCRevision      "15897 (Git)"      //Highest committed revision number
#define FCRevisionDate  "2019/02/16 15:30:46"     //Date of highest committed revision
#define FCRepositoryURL "git://github.com/FreeCAD/FreeCAD.git master"      //Repository URL of the working copy
// Git relevant stuff
#define FCRepositoryHash   "36dc7b42425dcb08abf6313c6dee6ce306b7bcdc"
#define FCRepositoryBranch "master"
FCRevision is 15897 which matches the number of commits shown on Github for master. That your revision number is higher was inexplicable to me, which led me to guess that you were pulling from a separate branch, not from master.
reox
Postby reox » Sun Feb 17, 2019 4:53 pm
15988
No, it's wrong.
Found it:
reox@helios ~/tmp/FreeCAD (git)-[master] % git rev-list --all --count
15995
reox@helios ~/tmp/FreeCAD (git)-[master] % git rev-list master --count
15901
so using --all uses all revs from all branches... Makes sense. I'll fix that in the build script!
NormandC
Postby NormandC » Sun Feb 17, 2019 5:54 pm
That explains it. I had a look at your script, but overlooked this, I'm really not very proficient with git... :oops:
Edit: your script is very interesting in that it manually creates the Version.h file without having to go through the CMake configuration process. This might be useful for the freecad-daily PPA repository. I wonder if these instructions could be added to a makefile (the /debian/rules file)? I'll ask the expert (kkremitzki)...
reox
Postby reox » Sun Feb 17, 2019 7:15 pm
Yes, first I used the gitversioning repo, but this takes ages to clone, as it contains many commits.
So this is basically a shortcut.
The problem is, that you need to create the file before merging with the gitpackaging repo, otherwise you get wrong commit IDs (and wrong rev numbers as well). Thus at buildtime the information is wrong. I think this is probably the reason for the versioning repo in the first place.
