[Improvement, partially SOLVED] Pages always display the internal name
vocx
Postby vocx » Thu Oct 18, 2018 11:11 pm
If I have a document and create several TechDraw pages, they are initially named Page, Page001, Page002, etc. However, it makes sense to rename the pages, for example, Page.front_view, Page.isometric, Page.elevations, whatever.
Despite the pages being renamed, the tabs that show the names are still shown with the internal name.
Screenshot from 2018-10-18 17-46-44.png (64.62 KiB) Viewed 550 times
Also, it's not possible to arrange which page goes first and which comes second. This is not a problem when you only have two pages, but if you have ten or more, it becomes cumbersome if you decide to create new pages and views later on.
So the improvement would be to be able to see the new names in the tabs, and to order the pages as you wish.
OS: Ubuntu 18.04.1 LTS
Version: 0.18.14979 (Git)
Hash: 47536dcd3729d3db106af628d62f2bf449e68c49
Python version: 2.7.15rc1
Re: [Improvement] Pages always display the internal name
Postby chrisb » Fri Oct 19, 2018 6:01 am
A group is perfect for ordering the pages. Insert them in the order you want and collapse the view to keep the tree view tidy, if they are not needed.
vocx
Postby vocx » Fri Oct 19, 2018 7:43 am
Yes, Std_Groups do help you organize the pages but it doesn't address the underlying issue. I think by now most users who've been following the development of FreeCAD since 0.16 know to use a lot of groups to keep the Model tree simple and logically organized; however, I think new users experience a bit of confusion when TechDraw Pages seem to behave in an odd way, not respecting name changes, and not being able to be ordered by dragging the tabs.
Besides, if you have many Pages, they are all opened when you first open your file in FreeCAD. Maybe the default should be to not open all TechDraw Pages?
Postby chrisb » Fri Oct 19, 2018 9:09 am
That has been discussed here before; please search the forum, probably the big TechDraw topic.
wandererfan
Postby wandererfan » Fri Oct 19, 2018 1:09 pm
I've been meaning to fix this for a while. Will try to get this into v0.18 before release.
Not really sure how to go about this. I believe the mainWindow arranges the tabs in the order they are created. I'm not sure if there is a convenient way to reorder the tabs. No promises on this one.
wandererfan
Postby wandererfan » Fri Oct 19, 2018 1:17 pm
If you set "Preferences->TechDraw1->KeepPagesUpToDate" to OFF, Pages will be created, but not drawn at startup. If you want to see a particular Page after startup, change the Page's KeepUpdated property. If you have big complicated drawings, this is the way to go.
Postby chrisb » Fri Oct 19, 2018 2:41 pm
Perhaps you can reuse the code from PartDesign's "Move object after other object".
vocx
Postby vocx » Fri Oct 19, 2018 9:33 pm
I see. To me this is not very intuitive. In my mind KeepUpdated should keep the 3D model and the projected views synchronized, but it should not affect whether the Pages appear at startup or not. Maybe it's possible to add another property, ShowAtStartup, to each page?
wandererfan
Postby wandererfan » Fri Oct 19, 2018 10:28 pm
In my mind KeepUdated should keep the 3D model and the projected views synchronized, but it should not affect whether the Pages appear at startup or not.
That is the intended purpose of "KeepUpdated". Not drawing the Page(s) at startup was just a side effect that turned out to be useful. Not intuitive, perhaps not even documented. Have to look into that.
vocx
Postby vocx » Fri Oct 19, 2018 10:36 pm
I don't know much Qt but I suspect it's one of the easiest things to do. Many programs nowadays use tabs whether using Gtk+ or Qt, like Gedit, DoubleCommander, Firefox and many others, and changing the order of the tabs is the most normal thing to do. Users practically expect to be able to do this in modern applications.
I searched online and it seems the component that does this is QTabWidget, https://stackoverflow.com/questions/167 ... tab-window, https://forum.qt.io/topic/30974/setting ... qtabwidget
In this thread the users demonstrate a simple program that subclasses QTabWidget, https://forum.qt.io/topic/67542/drag-ta ... bwidgets/6 They mention needing to define a couple of functions like mouseMoveEvent(), dragMoveEvent(), dropEvent(), etc., to know what to do with the tab when the mouse drags it.
The example from the aforementioned thread creates two panes with two tabs in each pane. The tabs can be moved with the left mouse button. To move a tab from one pane to the other pane, use the right mouse button.
This is the code
import sys
from PyQt5.QtGui import *
from PyQt5.QtWidgets import *
from PyQt5.QtCore import *
class Tabs(QTabWidget):
    def __init__(self, parent):
        super().__init__(parent)
        self.parent = parent
        self.setAcceptDrops(True)
        self.tabBar = self.tabBar()
        self.tabBar.setMouseTracking(True)
        self.indexTab = None
        self.setMovable(True)
        self.addTab(QWidget(self), 'Tab One')
        self.addTab(QWidget(self), 'Tab Two')
    def mouseMoveEvent(self, e):
        if e.buttons() != Qt.RightButton:
            return
        globalPos = self.mapToGlobal(e.pos())
        posInTab = tabBar.mapFromGlobal(globalPos)
        self.indexTab = tabBar.tabAt(e.pos())
        tabRect = tabBar.tabRect(self.indexTab)
        pixmap = QPixmap(tabRect.size())
        tabBar.render(pixmap,QPoint(),QRegion(tabRect))
        mimeData = QMimeData()
        drag = QDrag(tabBar)
        drag.setMimeData(mimeData)
        drag.setPixmap(pixmap)
        cursor = QCursor(Qt.OpenHandCursor)
        drag.setHotSpot(e.pos() - posInTab)
        drag.setDragCursor(cursor.pixmap(),Qt.MoveAction)
        dropAction = drag.exec_(Qt.MoveAction)
    def dragEnterEvent(self, e):
        e.accept()
        if e.source().parentWidget() != self:
            return
        print(self.indexOf(self.widget(self.indexTab)))
        self.parent.TABINDEX = self.indexOf(self.widget(self.indexTab))
    def dragLeaveEvent(self,e):
        e.accept()
    def dropEvent(self, e):
        print(self.parent.TABINDEX)
        if e.source().parentWidget() == self:
            return
        e.setDropAction(Qt.MoveAction)
        e.accept()
        counter = self.count()
        if counter == 0:
            self.addTab(e.source().parentWidget().widget(self.parent.TABINDEX),e.source().tabText(self.parent.TABINDEX))
        else:
            self.insertTab(counter + 1 ,e.source().parentWidget().widget(self.parent.TABINDEX),e.source().tabText(self.parent.TABINDEX))
class Window(QWidget):
    def __init__(self):
        super().__init__()
        self.TABINDEX = 0
        tabWidgetOne = Tabs(self)
        tabWidgetTwo = Tabs(self)
        layout = QHBoxLayout()
        self.moveWidget = None
        layout.addWidget(tabWidgetOne)
        layout.addWidget(tabWidgetTwo)
        self.setLayout(layout)
if __name__ == '__main__':
    app = QApplication(sys.argv)
    window = Window()
    window.show()
    sys.exit(app.exec_())
Save it as window_tabs.py and you can test it (in Ubuntu 18.04) with
python3 window_tabs.py
The code works with python2 but you need to modify the calls to super(), whose syntax apparently changed from Python 2 to 3. In Python 2 use
line  9: super(Tabs, self).__init__(parent)
line 73: super(Window, self).__init__()
And then you can run
python2 window_tabs.py
