[Bug, SOLVED] Rotated Annotation doesn't maintain rotated appearance
TechDraw_NewAnnotations have a property called Rotation to set the angle of the baseline of the annotation.
The rotation works when initially creating the annotation. However, if the TechDraw Page is closed (cross on the bottom tab or pressing the space bar to hide the Page), the appearance resets. That is, when opening the TechDraw Page again, the annotation still has the same Rotation in the Properties panel (for example, 90 degrees) but the annotation is shown horizontally as if it had a rotation of 0 degrees.
To correct the appearance, just enter the same value of rotation (for example, 90) into the property box and hit enter. This can be done for one or two annotations before converting the page to PDF or printing it, but it's cumbersome if you have many annotations, each with a different value of rotation.
OS: Ubuntu 18.04.1 LTS
Version: 0.18.14979 (Git)
Hash: 47536dcd3729d3db106af628d62f2bf449e68c49
Python version: 2.7.15rc1
- wandererfan
Re: [Bug] Rotated text doesn't maintain rotated appearance
Good catch. I've never noticed this. Please open a ticket for this so it doesn't get forgotten.vocx wrote: ↑Fri Oct 19, 2018 12:30 am The rotation works when initially creating the annotation. However, if the TechDraw Page is closed (cross on the bottom tab or pressing the space bar to hide the Page), the appearance resets. That is, when opening the TechDraw Page again, the annotation still has the same Rotation in the Properties panel (for example, 90 degrees) but the annotation is shown horizontally as if it had a rotation of 0 degrees.
Thanks,
wf
Where did you come from??? So many quality posts with very elaborate breakdowns. Great job. Hope you stick around.
+1. These contribution are in fact pleasant. Neither error reports nor feature proposals have the demanding attitude of many other newbie requests.Kunda1 wrote: ↑Fri Oct 19, 2018 3:15 pmWhere did you come from??? So many quality posts with very elaborate breakdowns. Great job. Hope you stick around.
I often use rotated annotations for surveyors dimensions aligned to the property lines, or for contour line heights.vocx wrote: ↑Fri Oct 19, 2018 12:30 am TechDraw_NewAnnotations have a property called Rotation to set the angle of the baseline of the annotation.
[/mono]
What I do is to edit the annotation; increment the rotation and then decrement it back to the correct value, the annotation will display correctly. This can be done quickly for several annotations, but it is only a temporary fix until the file is re-opened.
What works better is to open the model in FreeCAD .17 stable on Windows. I have no idea why this feature works correctly for an older version of FreeCAD but not for the newer releases.
My workaround? I install several releases of FreeCAD and use them according to which features I require at the time.
Has this been reported to the bug tracker?
OS: Windows 7
Version: 0.17.13522 (Git)
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.14
OCC version: 7.2.0
OS: Windows 7
OCC version: 7.2.0
It's been opened as issue #0003644.wandererfan wrote: ↑Fri Oct 19, 2018 2:07 pmGood catch. I've never noticed this. Please open a ticket for this so it doesn't get forgotten.vocx wrote: ↑Fri Oct 19, 2018 12:30 am The rotation works when initially creating the annotation. However, if the TechDraw Page is closed (cross on the bottom tab or pressing the space bar to hide the Page), the appearance resets. That is, when opening the TechDraw Page again, the annotation still has the same Rotation in the Properties panel (for example, 90 degrees) but the annotation is shown horizontally as if it had a rotation of 0 degrees.
Thanks,
wf
Yeah, I think there are a few regressions from stable 0.17 to the 0.18 daily builds but the jump is not so big, as it was from 0.16 to 0.17.BC-carpenter wrote: ↑Fri Oct 19, 2018 8:35 pm What works better is to open the model in FreeCAD .17 stable on Windows. I have no idea why this feature works correctly for an older version of FreeCAD but not for the newer releases.
I have different behaviour between 0.17 and 0.18 as well, but in 0.18 it is worse: The annotation never rotates. To make sure I'm doing it right:
- New document
- select TechDraw workbench
- create new default document (A4_LandscapeTD.svg)
- Click Icon "Insert annotation": Default Text appears
- Click Icon "Default Text" in 3D view
- Change rotation
Behaviour in 0.17:
- Text rotates immediately, even before leaving the field, after leaving the frame is updated
- After Save and reopen: Text is still rotated, but the frame is not rotated. Moving the mouse over the frame it rotates as well.
Behaviour in 0.18:
Nothing happens. Text is not rotated, even not after creation.
Opening a 0.17 document with rotated text: text is not rotated.
OS: Mac OS X
Version: 0.17.13541 (Git)
Qt version: 5.10.1
OCC version: 7.2.0
OS: macOS High Sierra (10.13)
Version: 0.18.14976 (Git)
Branch: (HEAD detached at e79a19828)
Hash: e79a19828e2e92269ff96110dfeadaa245ad17c2
Qt version: 5.11.2
OCC version: 7.2.0
- New document
- Change rotation
Behaviour in 0.17:
Behaviour in 0.18:
OS: Mac OS X
Qt version: 5.10.1
OCC version: 7.2.0
Qt version: 5.11.2
OCC version: 7.2.0
The text doesn't rotate at all in 0.18? I find that strange. It definitely rotates in my system, but the appearance restores itself after closing and opening again the page.chrisb wrote: ↑Sat Oct 20, 2018 7:47 am Behaviour in 0.17:
Behaviour in 0.18:
Difference in systems are you using Qt5 and OCC 7.2, while I use Qt4 and OCC 7.3.
Version: 0.18.14995 (Git)
Hash: 7b866816785ac1ca9787b63d4bff12873bb3a593
Both of my systems have the same OCC 7.2, while the Qt versions are slightly different. Let's see if wandererfan can find something which works on all systems.
