PDF Export
PDF Export
While exporting in PDF A4 Landscape, The export makes a A4 Portrait. It seems that exporting PDF does not respect format of the Drawing you made.
I haven't found any option to export to the right format. Any Clues ?
Thanx by advance.
Thanx by advance.
Re: PDF Export
Don't use File->Export... with subsequent selection of PDF type, use File->Export PDF instead (different menu entry).
Re: PDF Export
maybe something can help you in this video
- wandererfan
Re: PDF Export
I think the fix for this problem should also fix this. There should be an entry in the list of exportable formats called "Technical Drawing". That is the one to use.
Re: PDF Export
Cool! I just tested Technical Drawing export in PDF format, it works as expected.
This is the FreeCAD version that includes this new export option:
OS: Ubuntu 18.04.2 LTS
Version: 0.18.15883 (Git)
Build type: Unknown
Hash: 60f91fbef22e465386b9dc741c71d5c3103609f0
Python version: 3.6.7
Qt version: 5.9.5
Locale: French/Canada (fr_CA)
Build type: Unknown
Qt version: 5.9.5
Re: PDF Export
I seem to have the same issue with PDF export.
Trying to export an 11x17 drawing but I get a different size.
OS: Linux Mint 19.1
Version: 0.18.15860 (Git)
Hash: 3b708c7f84b0425076b520e1d95627b20fd75fe0
Python version: 2.7.15rc1
Qt version: 5.9.5
OS: Linux Mint 19.1
Qt version: 5.9.5
- wandererfan
Re: PDF Export - Tabloid/Ledger Paper
Tabloid/Ledger is always a problem. It is the only case where the same paper size has two entries in Qt's list of valid paper sizes - separate ones for portrait & landscape. Seems like the paper size overrides the orientation.
I'll see if I can figure out a special case for Tabloid/Ledger.
- wandererfan
Export to Tabloid/Ledger (Ansi B) paper should be fixed by this git commit dca9120de.
Re: PDF Export
Muchos Gratias, how long before this is available in the python 3.6 appimage download?wandererfan wrote: ↑Tue Feb 19, 2019 2:10 pm Export to Tabloid/Ledger (Ansi B) paper should be fixed by this git commit dca9120de.
- wandererfan
