Unwanted dependency message on deletion
If I delete a dimension from a page, I get a warning message:
These items are linked to items selected for deletion and might break.
Page
Are you sure you want to continue?
I can see from the dependency graph why this is so, but from a user's view it is strange. The use case is similar to having added a feature in PartDesign or a constraint in Sketcher, and there I never get such a message. Such a message makes me always uncomfortable because I don't know if something might really break - besides removing the measure, which I requested.
So my first question is, if there is a use case where something breaks?
And if not, is it possible to remove this question? I fear it comes from the very depths of FreeCAD.
wandererfan
Re: Unwanted dependency message on deletion
Post by wandererfan »
chrisb wrote: Mon Feb 11, 2019 9:21 am If I delete a dimension from a page, I get a warning message:
IIRC, deleting a linked DocumentObject (should) always displays this message. It comes from Gui::StdCmdDelete. Constraints are not DocumentObjects(?) so the message doesn't appear . Not sure why deleting a Feature from the chain doesn't trigger this message, because a PartDesign::Feature is a descendant of DocumentObject. Maybe PD uses it's own delete logic? I will have to investigate.
I don't believe there is a use case where deleting a Dimension breaks the View/Page. There were problems earlier in development, but they should all be fixed by now.
