I don't think this needs a bunch of words. The target and the detail are not lined up. See attached. Is this a bug or a setting?
I made a random rough cylinder to test an idea. My compute times were kind of long so I made a simple object to fine tune all my settings, then I can bring in a more complicated model and set most of the values all at one time.
Thanks
Detail center , offset from target
- detail_center_offset.FCStd
- (36.55 KiB) Downloaded 33 times
- wandererfan
Re: Detail center , offset from target
Some of this might be my fault, I have some older and newer versions of TD, sorry. I will get up to date on both my systems (win7-64,win10-64). I just installed 0.18.158 and the detail anchor point symbol changed to a box, see pic, must be something to do with symbols. Not sure how it would print, can't right now.
The alignment looks good between anchor and detail.
- detail44.JPG (55.83 KiB) Viewed 1109 times
- wandererfan
Pretty sure there's a bug somewhere. ProjectionGroupItems use slightly different code to make sure they aren't upside down or mirrored on the page. Let me know if your updates change anything.freedman wrote: ↑Mon Feb 18, 2019 10:40 pm Some of this might be my fault, I have some older and newer versions of TD, sorry. I will get up to date on both my systems (win7-64,win10-64). I just installed 0.18.158 and the detail anchor point symbol changed to a box, see pic, must be something to do with symbols. Not sure how it would print, can't right now.
There's a preference on the second tab called "matting style" that governs box vs circle.
It seems like there should be one under "Decorations" but it's not there (see pic). I did find one in Tools-Edit parameters-bla-bla Techdraw-Decorations. Am I missing something?There's a preference on the second tab called "matting style" that governs box vs circle.
If I wanted to erase some lines, what do you think is the best export.
This looks and works well. Thanks for your time and efforts.
- tech_decor.JPG (25.44 KiB) Viewed 1088 times
- wandererfan
"Tools-Edit parameters-bla-bla Techdraw-Decorations" is the parameter I meant. You may need a recompute or 2 after changing the preference.
I'd go with Svg. I don't like any of the Dxf based apps and I wouldn't know where to start with Pdf. I find Inkscape pretty straight forward for this sort of thing.
- wandererfan
git commit 77b22f4f3 should improve alignment of detail and source view for sources in a ProjectionGroup. Also introduces a Property to adjust the position of highlight circle/square on the source view:
- HighlightAdjust.png (33.11 KiB) Viewed 998 times
