Help on TechDraw source code
fjullien
Postby fjullien » Tue Feb 26, 2019 9:48 pm
I'm working on a new "balloon" command for TechDraw (an arrow with a circle on its end and a number inside this circle).
I'm starting to understand a bit how TechDraw works.
As a starting point I copied all DimensionView related files/calls into BalloonView ones. QGIViewBalloon functions are empty for now but QGIViewBalloon::draw gets called when I clic on my ballon command.
My problem it that I can't make my Balloon object a child of the selected view (in the Tree view at least). It is display at the same level as View.
Can someone (@wandererfan) can point me to the part of the code I should look closely ?
Thanks in advance.
Franck.
wandererfan
Re: Help on TechDraw source code
Postby wandererfan » Wed Feb 27, 2019 12:41 am
This is done in the parent's ViewProvider (ViewProviderViewPart.cpp) by the "claimChildren()" method. This is a general pattern for DocumentObjects.
Looking forward to seeing Balloon.
fjullien
Postby fjullien » Wed Feb 27, 2019 6:24 am
That's what I was actually looking at last night.
          } else if ((*it)->getTypeId().isDerivedFrom(TechDraw::DrawViewBalloon::getClassTypeId())) {
              temp.push_back((*it));
I stepped in the method with gdb and it seems like my Balloon was not in the view list so it can't be claimed.
I'll do some more tests tonight.
Thanks for your confirmation.
Franck.
wandererfan
Postby wandererfan » Wed Feb 27, 2019 1:45 pm
Does App/Balloon have a PropertyLink that points to a parentApp/DrawViewPart? If not, it won't be in the InList.
For DrawViewDimension (that's still your starting point?) the link(s) are in the References2D property.
    App::PropertyLinkSubList       References2D;                       //Points to Projection SubFeatures
fjullien
Postby fjullien » Wed Feb 27, 2019 7:30 pm
That was the problem. I removed too much of DrawViewDimension.
Let's continue !
fjullien
Postby fjullien » Sun Mar 10, 2019 9:17 pm
If you want to see how cool it is, look here:
https://github.com/fjullien/FreeCAD/commits/master
Select a view, click on the Balloon icon (a mean this kind of half circle) then click on a point in the view. The Balloon should appears.
Then drag the label to place it where you want. CTRL + label drag moves the ballon symbol.
Don't look at the code for now. Need to clean up, make proper commits, figure out what to do with App side of the code and write a test in TestTechDrawApp.py.
@wandererfan, did you design TechDraw icons yourself ?
Franck.
wandererfan
Postby wandererfan » Mon Mar 11, 2019 12:27 am
Very cool!
We inherited some, I did some, @agryson did some. Probably a few other contributors too.
triplus
Postby triplus » Mon Mar 11, 2019 12:37 am
Postby chrisb » Mon Mar 11, 2019 6:15 am
Ballons would be great. I had made these all different by hand in Inkscape:
Bildschirmfoto 2019-03-11 um 07.14.01.png (116.01 KiB) Viewed 1024 times
fjullien
Postby fjullien » Mon Mar 11, 2019 9:51 pm
I creted a PR here: https://github.com/FreeCAD/FreeCAD/pull/2013
Should I post anything somewhere else in the forum ?
Franck.
