I found a way to use PartDesign sketches as a helper line system for TechDraw, by putting a solid volume and an unpadded sketch (containing helper geometry) inside a body, and then selecting both of them together for a TechDraw view projection. Works nicely for ProjGroup view, but there is a problem with Detail views, where I get an error message:
The unpadded sketch is nicely visible and dimensionable for ProjGroup views, but I never seem to get anything else than abovementioned error messages for the Detail view based on the ProjGroup items.
FCStd file demonstrating the problem:
Nice addition would be to have the unused sketches inside a body to always project as thinner dashed lines, so that it would be obvious that they are just helper geometry. Now I just change the linetypes in Inkscape or some other svg program. I'm not sure if projecting sketches to TechDraw is intended use, but at the moment it works very nicely in all other cases than Detail views. Thanks!
FreeCAD version:
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.14
OCC version: 7.2.0
