Hello all,
I would like to publish my first FreeCAD code contribution. In the current state, if the TechDraw inner diameter line is not horizontal, it crosses the datum label like on the picture below:
From my point of view this is rather unfortunate and thus I am suggesting to place the inner diameter label above the dimension line, respecting the dimesion line tilt. For a better illustration, please see the same situation as above, but using my code changes:
I hope you will find this change useful and it will be possible to integrate it into the master. I have already created the pull request.
Kind regards,
Tomas
PS: Thanks to all contributors for this awesome software!
Change inner diameter label placement
Re: Change inner diameter label placement
Thanks, this seems to be conformant to what is called here DIN EN ISO 3098 standard.
- wandererfan
Marvellous! Thank you Tomas. git commit 243aebf2df
