Preliminary (alpha) versions of TechDraw_CosmeticVertex, TechDraw_Midpoints and TechDraw_Quadrant are available in master branch.
These functions allow the creation of otherwise impossible dimensions.
Test reports are very welcome.
Cosmetic Vertex Alpha Release
- wandererfan
Re: Cosmetic Vertex Alpha Release
Thank you so much Wandererfan. Great and helpful cosmetic vertex.wandererfan wrote: ↑Sat May 25, 2019 1:05 pm Preliminary (alpha) versions of TechDraw_CosmeticVertex, TechDraw_Midpoints and TechDraw_Quadrant are available in master branch.
In the wiki page, I personally recommend you to avoid adding a "Note: introduced in version 0.19". This information is already provided by the right floating box, the "GuiCommand" template. Basically, you are duplicating the information unnecessarily.wandererfan wrote: ↑Sat May 25, 2019 1:05 pm Preliminary (alpha) versions of TechDraw_CosmeticVertex, TechDraw_Midpoints and TechDraw_Quadrant are available in master branch.
In TechDraw Quadrant, the second note, "This tool can actually be used on any Edge, not just circles", should be in the "How to use" section as well. In my opinion, you should fully describe the tool in that section. "Notes" should be reserved for information that really can't be integrated easily into other sections.
Thanks a lot! This new functionality seems to fix many problem cases even in its preliminary alpha state! For example:wandererfan wrote: ↑Sat May 25, 2019 1:05 pm Preliminary (alpha) versions of TechDraw_CosmeticVertex, TechDraw_Midpoints and TechDraw_Quadrant are available in master branch.
I tested quadrants, midpoints, and arbitrary cosmeticvertices, and all of them worked the way I expected. So, seems good to me, notwithstanding the fact that I found no way to edit or remove any of the cosmeticvertices. Selecting a vertex and pressing delete removes the whole View, and removing vertices from the list in the View properties does nothing. I hope deleting CosmeticVertices will be added in the future, it'd make it easier to correct misplaced vertices. Also, adding "CosmeticEdges" with thin dot-dashed line between arbitrary vertices would be super helpful!
OS: Windows 10 (10.0)
Version: 0.19.16883 (Git)
Hash: aedb888ae3bb001175fe86211b6cfb826e31a918
Python version: 3.6.8
Qt version: 5.12.1
- wandererfan
Glad you like it. CosmeticEraser is being tested. CosmeticEdges are in development too.aapo wrote: ↑Fri May 31, 2019 12:47 pm So, seems good to me, notwithstanding the fact that I found no way to edit or remove any of the cosmeticvertices. Selecting a vertex and pressing delete removes the whole View, and removing vertices from the list in the View properties does nothing. I hope deleting CosmeticVertices will be added in the future, it'd make it easier to correct misplaced vertices. Also, adding "CosmeticEdges" with thin dot-dashed line between arbitrary vertices would be super helpful!
Great additions!
