Text in Balloon is too small
bitacovir
Postby bitacovir » Thu Jun 27, 2019 9:38 pm
Some observations about TechDraw Ballon
1) When I create a balloon in TDWB the text is too small. The Fontsize of the text in a balloon is 0.2mm
2) The start Start Symbol is missing.
Version: 0.19.17144 (Git)
Hash: ece1b7ecbaa36d22403d6850d8498882d820db3c
Python version: 3.6.6
Qt version: 5.6.2
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
fjullien
Re: Text in Balloon is too small
Postby fjullien » Fri Jun 28, 2019 7:52 am
Seems like it comes from language translation and how I preset the comboBox.
In my case, it searches for "Arrow" but combo text is "Flèche" (French).
What text do you have in your comboBox ?
    i = ui->comboEndType->findText(QString::fromUtf8(parent->dvBalloon->EndType.getValueAsString()));
    ui->comboEndType->setCurrentIndex(i);
    i = ui->comboSymbol->findText(QString::fromUtf8(parent->dvBalloon->Symbol.getValueAsString()));
ui->comboSymbol->setCurrentIndex(i);
Need to find another way to set comboBox here.
I'm wondering if something has changed here because I didn't do any translation work myself.
I even don't know how to do that :)
Thanks anyway for reporting.
Franck.
wandererfan
Postby wandererfan » Fri Jun 28, 2019 11:54 am
What are your settings for these settings - ArrowSize, ArrowStyle and FontSize? Do your Dimensions look right (shared parms with balloon)?
wandererfan
Postby wandererfan » Fri Jun 28, 2019 12:43 pm
I can't get "Fleche" in the combo box with FC language = Francais and locale = fr_Fr or fr_Ca. It always shows "Arrow".
Anyway, OP is in Australia, so probably not using French.
Use the index for setting and getting the combo box text:
//    i = ui->comboEndType->findText(QString::fromUtf8(parent->dvBalloon->EndType.getValueAsString()));
    i = parent->dvBalloon->EndType.getValue();
//    i = ui->comboSymbol->findText(QString::fromUtf8(parent->dvBalloon->Symbol.getValueAsString()));
    i = parent->dvBalloon->Symbol.getValue();
// and
        m_parent->dvBalloon->EndType.setValue(ui->comboEndType->currentIndex());
        m_parent->dvBalloon->Symbol.setValue(ui->comboSymbol->currentIndex());
The translation process pulls the literals from the ui file. Then the generated routine "void retranslateUi(QWidget *TechDrawGui__TaskBalloon)" does the translation at run time.
bitacovir
Postby bitacovir » Fri Jun 28, 2019 2:30 pm
Hi. Thanks for your attention. I fixed the problem deleting the configuration files in AppData>Roaming>FreeCAD
With a clean installation, the text and symbols are visible again.
Anyway, Balloon is working properly now.
::bitacovir::
My old Blog
