Techdraw WB - some weird lines are shown
71GA
Postby 71GA » Thu Aug 01, 2019 8:32 pm
I have finished my 3D model and now I have to supply the documentation using TechDraw workbench. Workbench shows two lines that shouldn't be there (attachment - marked with a yellow marker). What kind of lines are these two lines and how do I turn them off? I supply also the screenshot of the detail of the 3D model.
drawing.pdf
(709.79 KiB) Downloaded 24 times
3D model - detail screenshot.png (204.47 KiB) Viewed 486 times
dcapeletti
Re: Techdraw WB - some weird lines are shown
Postby dcapeletti » Thu Aug 01, 2019 11:12 pm
Hi, something similar happens to what happened to me. A few days ago I published it. https://forum.freecadweb.org/viewtopic.php?f=35&t=38118
wandererfan
Postby wandererfan » Fri Aug 02, 2019 12:43 am
What version are you using? If you are using freecad-daily (v0.19) you can use the line decorator to mark the lines invisible.
I can't tell you much else based on a screen grab and a PDF file. If you share the model (or a simpler version that shows the same problem) I might be able to tell you more.
Usually this is due to an invalid shape that confuses the hidden line removal algorithm.
71GA
Postby 71GA » Fri Aug 02, 2019 4:35 am
Here are the details of the version:
OS: Debian GNU/Linux 10 (buster)
Version: 0.18.
Python version: 2.7.16rc1
Qt version: 5.11.3
71GA
Postby 71GA » Fri Aug 02, 2019 4:38 am
Did you have transparency turned ON? I think it might be correlated to this...
dcapeletti
Postby dcapeletti » Fri Aug 02, 2019 10:55 am
Hi, no, it's not about transparency, it's about a projection error.
Greetings
Postby Kunda1 » Sat Aug 03, 2019 11:06 am
Moved thread to TD subforum
