Improved radius drawing
Jee-Bee
Re: Improved radius drawing
Postby Jee-Bee » Tue Aug 13, 2019 8:51 am
True, my comment was more or less to the whole difference between ISO, ASME , ... .
tpavlicek
Postby tpavlicek » Wed Aug 21, 2019 8:26 pm
Hi again!
So I went through the ASME Y14.5-2009 standard and now we are able to fully support it. Each dimension has a new property "StandardAndStyle" which allows the user to select the dimension appearance. Four values are supported in my draft:
1) ISO Oriented = straight line with the text tilted according to ISO 129-1
2) ISO Levelled = a bent line, with horizontal text above the reference line, as specified by ISO 129-1
3) ASME Regular = horizontal text, bent line with small reference line to text vertical center as specifies ASME Y14.5
4) ASME Inlined = straight line with level text on end, or inserted in the middle of line, though not crossed as ASME Y14.5 requires
Here are displayed all (typical) options:
Upper left corner - ISO Levelled
Upper right corner - ASME Regular
Bottom left corner - ISO Oriented
Bottom right corner - ASME Inlined
The dimensoin look is also affected by the additional "Extend To Center" property.
As @Jee-Bee suggested, the standard&style of a dimension is saved in the document, though it can be whenever changed. To improve the user experience, the default value for a newly created dimension can be specified via "Dimensioning Standard and Style" prefference added to page 2 of Tech Draw user settings.
I hope you will like these changes, I've created the pull request: https://github.com/FreeCAD/FreeCAD/pull/2443
Should there be any problems or modification suggestions, please do not hesitate and share them!
Kind regards,
Tomas
wandererfan
Postby wandererfan » Wed Aug 21, 2019 11:33 pm
This is terrific, Tomas. Thank you.
Not to wish bad luck on you or anything, but I hope you become unhappy with diameters, angles, etc! :lol:
Postby chrisb » Thu Aug 22, 2019 1:05 am
This is great!
Is there the possibility to set this in preferences too?
tpavlicek
Postby tpavlicek » Thu Aug 22, 2019 7:26 am
Hello,
I'm glad it worked out well :-)
:-D Yep, I guess diameters are the next ones...
Basically there is new default Standard and Style user preference in TechDraw' settings, page "TechDraw Dimensions". This says which style is to be used on a newly created dimension. Nevertheles, StandardAndStyle is a property of each dimension, which is saved in the document and it can be whenever switched to other standard/style. Are You missing some kind of preferences/settings?
Tomas
