[Macro] Snap Dimension lines to same length / re-center dimension
I have two idea what could improve elegancy of dimension lines:
1) if you have several dimensions next to each other (chain meausurement), it would be nice to be able to have all dimensions at the same length
2) You can move around the dimension number itself, but this might be by accident. Would it be possible to reset it to the center of the dimension line?
So for example: Edit: Here is the macro to actually do that: https://github.com/reox/FreeCAD_macros/ ... re.FCMacro
- wandererfan
Re: Snap Dimension lines to same length / re-center dimension
How about a chain dimension macro? The X and Y properties of the Dimension control where the text is located on the page. Collect some dimensions, average the Xs and Ys then update. The dimension and extension lines follow the text.reox wrote: ↑Sun Sep 01, 2019 6:01 pm I have two idea what could improve elegancy of dimension lines:
Probably quicker than waiting for me to code it.
That is a good idea. Should not be too hard!
A question for the macros: how can I check the instance of an object? For example I would like to know if all selected items are of type DrawViewDimension, but where is this type stored?
right now, I'm using this workaround:
In the code from TechDraw I found this:
Is that the correct way?
>>> isinstance(App.ActiveDocument.Dimension009, TechDraw.DrawViewDimension)
NameError: name 'TechDraw' is not defined
>>> import TechDraw
AttributeError: module 'TechDraw' has no attribute 'DrawViewDimension'
>>> dir(TechDraw)
['__doc__', '__file__', '__loader__', '__name__', '__package__', '__spec__', 'edgeWalker', 'findCentroid', 'findOuterWire', 'findShapeOutline', 'viewPartAsDxf', 'viewPartAsSvg', 'writeDXFPage', 'writeDXFView']
>>> App.ActiveDocument.Dimension009.__class__.__name__ == 'DrawViewDimension'
True
>>> App.ActiveDocument.Dimension009.isDerivedFrom("TechDraw::DrawViewDimension")
True
So, this would be the chain measure macro:
works really well!
A little bit more complicated is the re-centering of the value. I suppose the two points can be gathered using .getLinearPoints(), but I do not understand the transformation from these coordinates to the X/Y coordinate of the dimension? If you could hint me with the according lines of code in FC I can probably find out
Okay, found it. There are actually two different coordinate systems using the same origin, but they using different handyness, right?
So you simply take the average of the two coordinates but multiply the y coordinate by -1.
I added that now in the macro too!
works really well!
- wandererfan
That is the standard way of checking if an object is a DrawViewDimension or one of its descendents.reox wrote: ↑Mon Sep 02, 2019 6:33 am In the code from TechDraw I found this:Is that the correct way?Code: Select all
>>> App.ActiveDocument.Dimension009.isDerivedFrom("TechDraw::DrawViewDimension") True
If you want to check that it is a DVD but not a descendent, you can use this:
>>> d = App.ActiveDocument.Dimension
>>> d.TypeId
'TechDraw::DrawViewDimension'
- wandererfan
You've discovered one of the biggest PITA's in TechDraw. Model space uses garden variety 3d coords. Paper space uses Qt's 2d coords that have (0,0) at the upper left, +X pointing to the right, but +Y pointing down the screen/page.
Sometimes this is handled internally, but I've lost hours debugging things that only required inversion of Y.
*g* I remember when I first started doing stuff with computer graphics and all of it sudden, they would use left handed coordinate systems all over the place. But in mechanical engineering, the only valid coordinate system is right handedwandererfan wrote: ↑Mon Sep 02, 2019 11:57 amYou've discovered one of the biggest PITA's in TechDraw. Model space uses garden variety 3d coords. Paper space uses Qt's 2d coords that have (0,0) at the upper left, +X pointing to the right, but +Y pointing down the screen/page.
I always wonder why the computer graphics people dont want to adopt to the good stuff
thanks for the information!
Re: [Macro] Snap Dimension lines to same length / re-center dimension
It isn't too hard to calculate the coordinates for the Distance type, if you do a little bit of vector calculations
So, the macro supports now DistanceX, DistanceY and Distance types!
- wandererfan
Thanks a lot for this macro! Would it be actually possible that you publish it to the official FreeCAD macro repository, https://github.com/FreeCAD/FreeCAD-macros (according to the few criteria defined there)? Maybe other macros from your repository as well?reox wrote: Here is the macro to actually do that: https://github.com/reox/FreeCAD_macros/ ... re.FCMacro
Thanks a lot,
Gaël
