Solved by placing two projection sets (an extra one just with the corner views with a different scale). Not comfortable, but works as expected.
Hi!
This is maybe another one for the Master Of TechDraw wandererfan. (Thanks for all your efforts!)
Each item of a projection group has its own scale property.
Changing this does not change anything in the drawing.
Is it intended to work?
Or should the scale property of the item been hidden?
Same behaviour in Version 0.18.16131 and 0.19.18542
Same sample can be used for testing. Just try to shrink an item at the corners This feature is useful (in my opinion), but it might break ISO / ASME conformity.
Thanks,
Ingo
[Solved]Scale of items in a projection group does not work
- wandererfan
Re: Scale of items in a projection group does not work
The ProjectionGroup controls the scale for the individual items. The ScaleType and Scale properties on individual items should be hidden. They are currently marked "ReadOnly", but I'll change it to avoid confusion.
- wandererfan
What about leaving the corner view unchecked and inserting a regular view with the appropriate direction and scale?
Yes, that is a way to go.What about leaving the corner view unchecked and inserting a regular view with the appropriate direction and scale?
- wandererfan
Scale is hidden for ProjectionGroup items by this git commit a8ee33a754.wandererfan wrote: ↑Thu Oct 24, 2019 2:19 pm The ProjectionGroup controls the scale for the individual items. The ScaleType and Scale properties on individual items should be hidden. They are currently marked "ReadOnly", but I'll change it to avoid confusion.
ScaleType is still shown despite setting it to "hidden". Hopefully this isn't too big an inconvenience.
No Problem!wandererfan wrote: ↑Sun Oct 27, 2019 11:51 am [qScaleType is still shown despite setting it to "hidden". Hopefully this isn't too big an inconvenience.
Thank you!
