[Solved] Techdraw: no radius or diameter symbol
basmati
Postby basmati » Thu Oct 31, 2019 12:17 pm
When I try to create a new diameter dimension, I get no diameter symbol in the actual output.
The same goes for the R symbol on radiuses.
Whatever I add ion the Format String of the dimension (like a ° on angles) gets ignored (only the numer of decimals is being considered).
Is there a setting I overlooked or something I'm doing wrong?
Version info:
OS: macOS Mojave (10.14)
Version: 0.19.18589 (Git)
Hash: 3500451a040989d00693eab85b2a7c13ce4dad67
Python version: 3.7.3
Qt version: 5.12.5
Python console:
>>> # Gui.Selection.addSelection('Unnamed','View001')
>>> # Gui.Selection.clearSelection()
>>> # Gui.Selection.addSelection('Unnamed','View001','Edge0')
>>> ### Begin command TechDraw_NewDiameterDimension
>>> App.activeDocument().addObject('TechDraw::DrawViewDimension','Dimension')
>>> App.activeDocument().Dimension.Type = 'Diameter'
>>> App.activeDocument().Page.addView(App.activeDocument().Dimension)
>>> ### End command TechDraw_NewDiameterDimension
Bildschirmfoto 2019-10-31 um 12.31.53.png (165.64 KiB) Viewed 371 times
Bildschirmfoto 2019-10-31 um 12.31.08.png (85.67 KiB) Viewed 371 times
wandererfan
Re: Techdraw: no radius or diameter symbol
Postby wandererfan » Thu Oct 31, 2019 1:21 pm
Everything seems to work here, but I am ~100 commits ahead of you and there was a lot of work done on Dimensions recently.
OS: Linux Mint 19 (X-Cinnamon/cinnamon)
Version: 0.19.18644 +4 (Git) <<<<<<<<<
Build type: debug
Branch: Extent
Hash: d84de6b89c2cc0532362a24205f28f63a45fd403
Python version: 3.6.8
Qt version: 5.9.5
Version info:
Qt version: 5.12.5
basmati
Postby basmati » Thu Oct 31, 2019 1:59 pm
Then I will just cross my fingers and hope there will soon be an update Mac OS version online.
aapo
Postby aapo » Fri Nov 01, 2019 11:27 am
This version has exactly the bug you described, it has been fixed at around ~ v 0.19.18600.
EDIT: Here is the relevant thread https://forum.freecadweb.org/viewtopic.php?f=35&t=40175. It seems you actully have a version that is just one commit too old.
basmati
Postby basmati » Tue Nov 05, 2019 4:26 pm
I just downloaded 18644 from the Github releases pages, everything works now as expected.
Postby Kunda1 » Tue Nov 05, 2019 5:34 pm
Please mark [Solved]
