Crash using Add quadrant vertices
Postby chrisb » Sun Nov 03, 2019 10:29 am
When using "Add quadrant vertices" I get a crash, if nothing is selected.
Steps to reproduce:
- start FreeCAD, switch to TechDraw
- open attached file
- without doing anything else call Menu->TechDraw->Add quadrant vertices
-> crash!
Furthermore:
- if I select the view before calling Add quadrant vertices, nothing happens (no crash, no additional points)
- if I select either one or both circles before calling Add quadrant vertices, nothing happens (no crash, no additional points)
- if I select the face between the circles before calling I get the expected message: "Please select only Edges for this function"
- On some occasions the quadrant points occur though, but I could not reproduce the sequence of tries of selections of the circles and the view
OS: macOS High Sierra (10.13)
Version: 0.19.18644 (Git)
Hash: 481870be2b48ef95b59acf1440b069d42b6fad23
Python version: 3.7.3
Qt version: 5.12.5
Locale: English/Germany (en_DE)
quadrantVertices.FCStd
(11.7 KiB) Downloaded 9 times
Syres
Re: Crash using Add quadrant vertices
Postby Syres » Sun Nov 03, 2019 12:25 pm
On Windows, no hard crash but in Report View and a dialog box produced with the following:
Illegal storage access...
<Exception> Illegal storage access! Please save your work under a new file name and restart the application!
I can also confirm all your points in the 'Furthermore' paragraph.
OS: Windows 7 SP 1 (6.1)
Python version: 3.6.7
Qt version: 5.12.1
vocx
Postby vocx » Sun Nov 03, 2019 7:05 pm
This is the backtrace
Thread 1 "FreeCAD" received signal SIGSEGV, Segmentation fault.
0x00007fff5db00a5e in TechDraw::DrawViewPart::getEdgeGeometry (this=0x0)
    at /opt/freecad-source-vocx/src/Mod/TechDraw/App/DrawViewPart.cpp:579
579	    return geometryObject->getEdgeGeometry();
(gdb) bt
#0  0x00007fff5db00a5e in TechDraw::DrawViewPart::getEdgeGeometry() const (this=0x0)
#1  0x00007fff5e1081a8 in execQuadrant(Gui::Command*) (cmd=0x555555eb41f0)
    at /opt/freecad-source-vocx/src/Mod/TechDraw/Gui/CommandAnnotate.cpp:401
#2  0x00007fff5e108d11 in CmdTechDrawQuadrant::activated(int) (this=0x555555eb41f0, iMsg=0)
    at /opt/freecad-source-vocx/src/Mod/TechDraw/Gui/CommandAnnotate.cpp:534
#3  0x00007ffff6c33129 in Gui::Command::invoke(int, Gui::Command::TriggerSource) (this=0x555555eb41f0, i=0, trigger=Gui::Command::TriggerAction) at /opt/freecad-source-vocx/src/Gui/Command.cpp:408
#4  0x00007ffff6c2410e in Gui::Action::onActivated() (this=0x5555563d1ad0) at /opt/freecad-source-vocx/src/Gui/Action.cpp:96
#5  0x00007ffff6c2992f in Gui::Action::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) (_o=0x5555563d1ad0, _c=QMetaObject::InvokeMetaMethod, _id=0, _a=0x7fffffffbd90) at /opt/freecad-build-vocx/src/Gui/moc_Action.cpp:74
#6  0x00007ffff2c32645 in QMetaObject::activate(QObject*, int, int, void**) (sender=sender@entry=0x555557294140, signalOffset=<optimized out>, local_signal_index=local_signal_index@entry=1, argv=argv@entry=0x7fffffffbd90) at kernel/qobject.cpp:3767
#7  0x00007ffff2c32d17 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) (sender=sender@entry=0x555557294140, m=m@entry=0x7ffff4044e00 <QAction::staticMetaObject>, local_signal_index=local_signal_index@entry=1, argv=argv@entry=0x7fffffffbd90)
    at kernel/qobject.cpp:3629
#8  0x00007ffff397b122 in QAction::triggered(bool) (this=this@entry=0x555557294140, _t1=<optimized out>) at .moc/moc_qaction.cpp:370
#9  0x00007ffff397d80c in QAction::activate(QAction::ActionEvent) (this=0x555557294140, event=<optimized out>) at kernel/qaction.cpp:1165
#10 0x00007ffff3afa0fc in QMenuPrivate::activateCausedStack(QVector<QPointer<QWidget> > const&, QAction*, QAction::ActionEvent, bool) (this=this@entry=0x5555584524a0, causedStack=..., action=action@entry=0x555557294140, action_e=action_e@entry=QAction::Trigger, self=self@entry=true) at widgets/qmenu.cpp:1323
#11 0x00007ffff3b015ab in QMenuPrivate::activateAction(QAction*, QAction::ActionEvent, bool) (this=this@entry=0x5555584524a0, action=action@entry=0x555557294140, action_e=action_e@entry=QAction::Trigger, self=self@entry=true) at widgets/qmenu.cpp:1400
---Type <return> to continue, or q <return> to quit---
Wandererfan just pushed some commits to master, so maybe we should try again with the current 0.19.18661.
wandererfan
Postby wandererfan » Mon Nov 04, 2019 12:26 am
Should be fixed by git commit c2851ae4b6. Similar fault in "Midpoints" fixed too.
