DXF Export using TechDraw classes
petit_chat_noir
Re: TechDraw feature request
Postby petit_chat_noir » Thu Nov 14, 2019 6:20 pm
I've worked on it today.
this is the source :
Now I Have layers aligned by creating bounding box:
here is the model exported with "temp" line in red :
and if I hide "temp" layer:
Now I have to suppress doubles, remove the bounding box, and the hardest point, color splitted lines :P
EDIT: after remove doubles :mrgreen:
Is there a function to test if edges are collinear ? I will have to test that to color splitted lines
I've to rework on bounding box lines, they have to be more small to not much interact with the render
The source code is available on my github workbench :
https://github.com/JeromeL63/Wood-Frame
the macro to launch :
from WFrame import WFDxfExport
export = WFDxfExport.DxfExport(Gui.Selection.getSelection())
export.extractLayers()
export.extractModel()
export.save()
You have to select objects and layers you want to export before launch
(sorry I haven't made security to launch with no selected objects at the moment !)
Postby Kunda1 » Fri Nov 15, 2019 12:40 pm
Moved to TD subforum
petit_chat_noir
Postby petit_chat_noir » Sat Nov 16, 2019 3:25 pm
Hello !
done !!
and this is the result in draftsight :
I'm very very happy :D
They are some mistakes but it's quite good !
update my github workbench if you want to use it.
I'll make button and dialog taskbox to use it in few days
petit_chat_noir
Re: DXF Export using TechDraw classes
Postby petit_chat_noir » Sat Nov 16, 2019 3:38 pm
yorik wrote:
Mon Nov 11, 2019 9:15 pm
ping
wandererfan wrote:
Wed Nov 13, 2019 2:43 pm
ping
I don't know if work like that ....
wandererfan
Postby wandererfan » Sun Nov 17, 2019 2:17 pm
ping
ping
:? I don't understand the ping, but I'm happy you got the result you were looking for.
Je ne comprends pas le ping, mais je suis content que tu as obtenu ton resultat.
petit_chat_noir
Postby petit_chat_noir » Tue Nov 19, 2019 7:22 pm
No problem, it was just to show you that you helped me a lot !
vocx
Postby vocx » Wed Nov 20, 2019 4:50 pm
export.save()
If this is something that can be merged into Draft for DXF export, you should look into it instead of keeping it in your external workbench.
I see that you are using "ezdxf". What is this exactly?
petit_chat_noir
Postby petit_chat_noir » Thu Nov 21, 2019 3:52 pm
I think this tool has not his place in draft, but more probably in arch. I'm trying to make functions to use it easly, so I will post discussion after the tool will be released.
It will probably work for draft objects too !
EzDxf is a python library/package(MIT licence) that provide good functions to create/write dxf files. A member told me it's existance, and I tried.
https://ezdxf.readthedocs.io/en/master/
vocx
Postby vocx » Thu Nov 21, 2019 4:39 pm
Just for reference, Arch is built on top of Draft. Arch actually uses the Draft routines to export DXFs and do many other things, so that's why I suggest adding the code directly to Draft.
petit_chat_noir
Postby petit_chat_noir » Fri Nov 22, 2019 5:20 pm
OK no problem vocx, thanks for the information.
I'm making some tests, and I'll push on my workbench before introduce it in draft :D
