[Solved] missing auto-apply for cross section view label
uwestoehr
Postby uwestoehr » Mon Dec 09, 2019 6:54 pm
- create a new page ad there a view
- select the view and insert a section view
- in the appearing task dialog click on the button "looking up", then insert the Identifier "A" and eventually press OK
result: The Identifier is missing. So after it has been defined in the task dialog an apply is missing (one must at the moment press Apply before one can click OK)
svbol
Re: missing auto-apply for cross section view label
Postby svbol » Sat Dec 14, 2019 5:27 am
Yes, I have this problem too.
I see line A-A in my Front view, but not see "Section A-A" under my section.
Usually I use two sections. And section's name very important for me.
OS: Linux Mint 18.2 32 bit
FreeCAD Daily last build
wandererfan
Postby wandererfan » Sat Dec 14, 2019 1:46 pm
I see line A-A in my Front view, bit not see "Section A-A" under my section.
Just a reminder that Labels are not displayed on printed/exported copies of the drawing by default. You can either fill in the Caption property or set the View's KeepLabel property to true if you want text under the View in the final result.
bitacovir
Postby bitacovir » Sun Dec 15, 2019 12:59 am
It is recommended using: Help menu / About FreeCAD / Copy to clipboard
for FreeCAD version details.
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
wandererfan
Postby wandererfan » Sun Dec 29, 2019 6:19 pm
Should be fixed by git commit 4cca918a76 and git commit e33a90dc50.
uwestoehr
Postby uwestoehr » Fri Jan 03, 2020 1:02 pm
It is not completely fixed. This case still fails:
1. select a view and insert a section view
2. in the appearing task dialog click first on the button looking up then insert as identifier "G" and eventually press OK
Doing it the other way round (first entering the identifier, then pressing the button to define the section type) works now.
wandererfan
Postby wandererfan » Sat Jan 04, 2020 3:02 pm
git commit 0ef89a9e57
uwestoehr
Postby uwestoehr » Sat Jan 04, 2020 11:20 pm
Many thanks. I tested and it works fine now.
Postby Kunda1 » Tue Jan 07, 2020 6:36 pm
Can this thread be marked [Solved] ?
