Drawing link object in a page with techdraw
wandererfan
Re: Drawing link object in a page with techdraw
Postby wandererfan » Thu Mar 26, 2020 6:48 pm
realthunder wrote: ping
in TR001_Beam+End_Plate_Drawing.FCStd (previous post), calling Part::Feature::getShape(TR001) returns
a Compound that looks like this:
The endplates should be aligned with the beam as here:
Should I expect the endplates to be in their final position, or do I need to disassemble the Compound and apply a placement
on the sub-shapes?
Thanks.
SEgetShape.brep
(56.54 KiB) Downloaded 9 times
DDM
Postby DDM » Thu Mar 26, 2020 8:24 pm
on the sub-shapes?
Yes, the end plates should be in the final position.
It isn't a compound. I created the TR001 using "Make link group/Simple Group".
My steps were:
1) for the beam (P001): a structural element from arch workbench
2) for the end plates (P002): sketch--->>extrude (part workbench) --->>> structure (arch workbench)
3) move the end plate to the final position
3) links of P001 end P002 (for P002 I set the "element count" property to 2 and I move one end plate at the end of the beam)
4) "link trasnform" property of the links set to TRUE
5) create the link group (TR001)
6) create a link of the Link Gruop in the "TR001_Beam+End_Plate_Drawing.FCStd" file
7) create the page and the drawing of the LK_TR001, LK_P001, LK_P002
a Compound
I think that the link object does not see the placement of the arch object, but it use the placement of the base element (i.e. the placement of the extrude part or the sketch).
Marco
wandererfan
Postby wandererfan » Thu Mar 26, 2020 11:51 pm
Yes, but I'm not referring to how TR001 was created.
The compound is returned from Part::Feature::getShape(). This is one of the functions that TD uses to retrieve the OpenCascade shape for objects to be drawn. Usually getShape provides ready to use shapes, but here it does not. Hence the question.
realthunder
Postby realthunder » Fri Mar 27, 2020 4:44 am
on the sub-shapes?
It's a bug in handling of link array with LinkTransform. PR submitted here.
DDM
Postby DDM » Fri Mar 27, 2020 9:00 am
Sorry @Wandererfan, I don't understand the question...Thanks for the expalnation, very useful to understand how TD works...
Cheers,
Marco
DDM
Postby DDM » Fri Mar 27, 2020 11:27 am
I tried to set FALSE the property "Link Transform" and to place the Link parts in the final position (See screenshot001)
Now TD draw the TR001 correctly...
Here atteched the last example (V1 version)...
But there is another problem.
When I close the file with the page (TR001_Beam+End_Plate_Drawing_V1.FCStd) and I open the same file I lose the single parts and the report view show this:
DVP::execute - No Sources (but document is restoring) - ProjItem002
Here atteched the screenshot of what I see (Screenshot002)
Thanks for looking in to it...
Marco
(11.06 KiB) Downloaded 7 times
Beam+End_Plate_V1.FCStd
(26.67 KiB) Downloaded 8 times
wandererfan
Postby wandererfan » Fri Mar 27, 2020 4:05 pm
Much better. Thank you!
wandererfan
Postby wandererfan » Fri Mar 27, 2020 4:18 pm
I get a whole series of warning messages:
<PropertyLinks> PropertyLinks.cpp(774): Lost link to TR001_Beam_End_Plate_Drawing Link001 while loading, maybe an object was not loaded correctly
11.221 <App> Document.cpp(2718): Reload partial document Beam_End_Plate
DVP::execute - No Sources (but document is restoring) - ProjItem003
QXcbConnection: XCB error: 3 (BadWindow), sequence: 7163, resource id: 61110124, major code: 40 (TranslateCoords), minor code: 0
I don't know what most of them mean, but I know how to fix the Views. Update the Source property of the affected Views (click on the empty field, then press the ellipsis button and select TR001.
DDM
Postby DDM » Fri Mar 27, 2020 6:36 pm
I don't see the objects P001 and P002 to update the source (see screnshot_003). I can use only the TR001 as source for ProjGroup001 and ProjGroup002...
Did I make a mistake?
Thanks for your help...
wandererfan
Postby wandererfan » Fri Mar 27, 2020 9:28 pm
I don't see them either.
Do you get these messages in the Report View?
