[fixed] new leader lines appear outside of tree
uwestoehr
Postby uwestoehr » Mon Jan 13, 2020 10:31 pm
- open this example file:
TD-test.FCStd
test file
(137.27 KiB) Downloaded 7 times
- select the section view A-A and the insert a leader line
result: the leader line appears outside of the tree:
outside of tree
- save and reopen the document
result: now everything is correct:
correctly inside tree
OS: Windows 7 SP 1 (6.1)
Version: 0.19.19263 (Git)
Hash: c4ca00a1d5b7922ef1d2ae3e820bb34ffdb64d9f
Python version: 3.6.8
Qt version: 5.12.1
Re: new leader lines appear outside of tree
Postby chrisb » Mon Jan 13, 2020 10:59 pm
Redraw is sufficient here. It shows in report view
Dimension has invalid 2D References
QGIT::makeSymbol - no symbol file set
Perhaps these should be fixed before to make sure they are not connected to the issue reported.
uwestoehr
Postby uwestoehr » Mon Jan 13, 2020 11:03 pm
The dimension in the test file can be ignored. Here is the file without the dimension and the bug occurs nevertheless:
TD-test.FCStd
better test file
(137.03 KiB) Downloaded 6 times
wandererfan
Postby wandererfan » Wed Jan 15, 2020 8:48 pm
Should be fixed by git commit 8b2e318f15
uwestoehr
Postby uwestoehr » Fri Jan 17, 2020 5:13 pm
Many thanks, this is now fixed.
