Geometric Dimensioning & Tolerancing
lidiriel
Postby lidiriel » Tue Jan 14, 2020 9:48 am
Hi freecad team,
I'm not sure is it the good place to post : but i have create a pull request for a new feature :
It is a small tool : Geometric Dimensioning & Tolerancing (GDT) Reference.
It is my first dev for freecad and a first part for next feature that i would implement : a feature control frame.
https://travis-ci.org/FreeCAD/FreeCAD/builds/636791878
https://github.com/lidiriel/FreeCAD/tree/gdt-reference2
I have rebase the branch gdt-reference2 to master.
what should i do now ?
by
lidiriel
lidiriel
techdraw : new feature
Postby lidiriel » Tue Jan 14, 2020 1:31 pm
Hi freecad team and sorry for my old post in bad thread.
by
lidiriel
fjullien
Re: Geometric Dimensioning & Tolerancing
Postby fjullien » Tue Jan 14, 2020 2:58 pm
Your code must first pass travis-CI then you should wait for your code to be reviewed.
Franck.
Re: techdraw : new feature
Postby Kunda1 » Tue Jan 14, 2020 6:25 pm
Did you submit a PR?
That way the CI can build it and the devs can review the code
CarloGreen
Postby CarloGreen » Tue Jan 14, 2020 6:46 pm
I don't know if you are aware that there is an older GD&T toolbox. Maybe you can use some code from the other toolbox to make your life easier.
https://github.com/juanvanyo/FreeCAD-GDT
https://forum.freecadweb.org/viewtopic.php?t=35887
lidiriel
Postby lidiriel » Tue Jan 14, 2020 8:14 pm
Thanks for the link CarloGreen. I will inspect the code to get idea.
Site Admin
Postby wmayer » Tue Jan 14, 2020 11:22 pm
I have merged your two threads and moved it to the TechDraw development forum.
wandererfan
Postby wandererfan » Wed Jan 15, 2020 2:45 am
I played with this a bit tonight. It looks good!
Some notes:
- - debug message about "References2D"
- aspect ratio of symbol when text gets longer. Should it turn into rectangle when text length >> text height?
- point of the leader slides past ends of edge. Would be nice if it stopped at the ends, but not a big deal for v1
- label could be just "Reference". the tree is very crowded aready.
- not sure this is a "dimension". "reference" and "balloon" should go into annotations menu some day. maybe a separate gdt menu.
- next sequential reference - see DrawPage.NextBalloonIndex()
lidiriel
Postby lidiriel » Wed Jan 15, 2020 8:21 am
Thanks wmayer : sorry for the extra work.
lidiriel
Postby lidiriel » Wed Jan 15, 2020 9:23 am
thanks a lot : i correct these as soon as possible
Some notes:
