Lost Faces
sliptonic
Lost Faces
Post by sliptonic »
I drew a sketch like this:
It was revolved and mirrored to make the part. I made the outer side from two edges because I wanted a face that I could hatch in the drawing
But when I select the part and add the projection group/view I get the points but lose the edges that connect them and the faces are merged. Is there a setting to keep them discrete?
TDlostface.FCStd
(40.97 KiB) Downloaded 11 times
sliptonic
SOLVED: Lost Faces
Post by sliptonic »
Found it myself. Seam Visible = True.
