RichTextAnnotation issues
uwestoehr
Postby uwestoehr » Sat Jan 25, 2020 12:24 pm
I think there are some issues in the RichTextAnnotation feature:
stroke through items are meanwhile resolved
  • Create a new annotation and set the option "Show Frame". Select the annotation in the tree and go to the View properties tab. There change the color of the frame
    -> result: nothing happens
    select another element in the tree
    -> result: now the changed color is shown
    This bug also happens for Line Style and Line Width
  • Select the annotation in the tree and go to the View properties tab. The frame setting Line Style has numbers. But since this settings offers line styles, it should instead of a number be a combo box showing the different styles. The Leader Line dialog offers this in a basic form:
    Leader Line Dialog
    This way it is assured that the user cannot e.g. enter "6" as there are only 5 styles available. -> one can now only set in the range 0 - 5
    Here is an example of how Inkscape does it using images:
    screenshot from Inkscape
  • The Richt Text dialog has no settings for the frame line color/width and style like, The Leader Line Dialog has it -> I'll try to make PR.
  • The frame Line Width setting has no unit. It is millimeter -> I'll try to make a PR
  • Set the frame Line Width setting to e.g. "7".
    -> result: it looks ugly:
    Line Width 7
  • Open the annotation dialog by double-clicking on the annotation in the tree. Remove there the frame option. Then close the dialog, select the annotation in the tree and go to the View properties tab.
    -> result: the 3 entries for the frame are enabled despite there is no frame. They should therefore be disabled.
  • I already reported the missing default text size issue here
OS: Windows 7 SP 1 (6.1)
Version: 0.19.19363 (Git)
Hash: e434d1145de6e964deca65698c4a162c331f52b5
Python version: 3.6.8
Qt version: 5.12.1
uwestoehr
Re: RichTextAnnotation issues
Postby uwestoehr » Sun Jan 26, 2020 1:58 am
[*] Create a new annotation and set the option "Show Frame". Select the annotation in the tree and go to the View properties tab. There change the color of the frame
This PR fixes it: https://github.com/FreeCAD/FreeCAD/pull/2939
uwestoehr
Postby uwestoehr » Sun Jan 26, 2020 3:39 pm
[*] The frame Line Width setting has no unit. It is millimeter -> I'll try to make a PR
This PR adds this for all LineWidth occurrences in TD: https://github.com/FreeCAD/FreeCAD/pull/2942
uwestoehr
Postby uwestoehr » Sun Jan 26, 2020 5:16 pm
The frame setting Line Style has numbers....
At the moment the user can there enter e.g. "6" but there are only 5 styles available.
This is fixed by the PR: https://github.com/FreeCAD/FreeCAD/pull/2942
wandererfan
Postby wandererfan » Sun Jan 26, 2020 7:54 pm
This fixes it without the extra repainting of calling "updateGraphic" twice for the 3 RTA ViewProvider properties and once for every ancestor VP property.
@@ -124,6 +124,15 @@ void ViewProviderRichAnno::updateData(const App::Property* p)
 void ViewProviderRichAnno::onChanged(const App::Property* p)
+    if ((p == &LineColor) ||
+        (p == &LineWidth) ||
+        (p == &LineStyle)) {
+        QGIView* qgiv = getQView();
+        if (qgiv) {
+            qgiv->updateView(true);
     ViewProviderDrawingView::onChanged(p);
uwestoehr
Postby uwestoehr » Sun Jan 26, 2020 10:06 pm
I don't understand because this is exactly what the new void updateGraphic() does.
wandererfan
Postby wandererfan » Mon Jan 27, 2020 12:54 am
This way is consistent with the other ViewProviders and only repaints on changes to interesting properties.
uwestoehr
Postby uwestoehr » Mon Jan 27, 2020 9:41 am
OK. Then please close my PR and do it consistently. Or should I do this?
wandererfan
Postby wandererfan » Mon Jan 27, 2020 1:24 pm
I've got this one, thanks.
uwestoehr
Postby uwestoehr » Mon Jan 27, 2020 1:58 pm
Thanks. I close my PR now.
