crash on selecting TD element in tree when page not shown
uwestoehr
Postby uwestoehr » Fri Feb 14, 2020 12:39 am
- open this example file:
Cube.FCStd
testfile
(39.51 KiB) Downloaded 7 times
As you can see the page is not shown. This is important to reproduce the crash.
- double click in the tree on the entry "LeaderLine"
result: you get this error:
Illegal storage access...
<Exception> Illegal storage access! Please save your work under a new file name and restart the application!
Afterwards FC will crash sooner or later.
OS: Windows 10 (10.0)
Version: 0.19.19570 (Git)
Hash: 53bbf09bf9a624428808c2d528949092adb6fdbf
Python version: 3.6.8
Qt version: 5.12.1
Re: crash on selecting TD element in tree when page not shown
Postby chrisb » Fri Feb 14, 2020 6:18 am
Confirmed, crashes here immediately.
OS: macOS High Sierra (10.13)
Version: 0.19.19541 (Git)
Hash: a797a4172709b82c6cd08dcf6df86cb789aaa3ce
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Locale: English/Germany (en_DE)
vocx
Postby vocx » Sat Feb 15, 2020 5:46 am
I also get immediate crash.
I guess the problem is in TaskLeaderLine.cpp with TechDrawGui::ViewProviderLeader.
I'm on 0.19.19591.
Thread 1 "FreeCAD" received signal SIGSEGV, Segmentation fault.
0x00007fff551361ae in TechDrawGui::TaskLeaderLine::TaskLeaderLine (this=0x55555b72ed50, leadVP=0x555555e60640)
    at /opt/freecad-source-vocx/src/Mod/TechDraw/Gui/TaskLeaderLine.cpp:110
110	    m_scene = m_mdi->m_scene;
(gdb) bt
#0  0x00007fff551361ae in TechDrawGui::TaskLeaderLine::TaskLeaderLine(TechDrawGui::ViewProviderLeader*) (this=0x55555b72ed50, leadVP=0x555555e60640) at /opt/freecad-source-vocx/src/Mod/TechDraw/Gui/TaskLeaderLine.cpp:110
#1  0x00007fff55139ae2 in TechDrawGui::TaskDlgLeaderLine::TaskDlgLeaderLine(TechDrawGui::ViewProviderLeader*) (this=
    0x55555b5d3160, leadVP=0x555555e60640) at /opt/freecad-source-vocx/src/Mod/TechDraw/Gui/TaskLeaderLine.cpp:770
#2  0x00007fff55218ff5 in TechDrawGui::ViewProviderLeader::setEdit(int) (this=0x555555e60640, ModNum=0)
    at /opt/freecad-source-vocx/src/Mod/TechDraw/Gui/ViewProviderLeader.cpp:101
#3  0x00007fff5521909c in TechDrawGui::ViewProviderLeader::doubleClicked() (this=0x555555e60640)
    at /opt/freecad-source-vocx/src/Mod/TechDraw/Gui/ViewProviderLeader.cpp:123
#4  0x00007ffff6e1489a in Gui::TreeWidget::mouseDoubleClickEvent(QMouseEvent*) (this=0x555555e638d0, event=0x7fffffffc950)
    at /opt/freecad-source-vocx/src/Gui/Tree.cpp:1314
#5  0x00007ffff38cd95f in QWidget::event(QEvent*) (this=this@entry=0x555555e638d0, event=event@entry=0x7fffffffc950)
    at kernel/qwidget.cpp:8904
#6  0x00007ffff396e4de in QFrame::event(QEvent*) (this=0x555555e638d0, e=0x7fffffffc950) at widgets/qframe.cpp:550
#7  0x00007ffff3ae1b8b in QAbstractItemView::viewportEvent(QEvent*) (this=this@entry=0x555555e638d0, event=event@entry=0x7fffffffc950) at itemviews/qabstractitemview.cpp:1748
#8  0x00007ffff3b4a52c in QTreeView::viewportEvent(QEvent*) (this=0x555555e638d0, event=0x7fffffffc950)
    at itemviews/qtreeview.cpp:1326
#9  0x00007ffff2b105bc in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) (receiver=receiver@entry=0x555555e01db0, event=event@entry=0x7fffffffc950) at kernel/qcoreapplication.cpp:1135
#10 0x00007ffff388e815 in QApplicationPrivate::notify_helper(QObject*, QEvent*) (this=this@entry=
    0x5555559dac10, receiver=receiver@entry=0x555555e01db0, e=e@entry=0x7fffffffc950) at kernel/qapplication.cpp:3718
#11 0x00007ffff389665f in QApplication::notify(QObject*, QEvent*) (this=<optimized out>, receiver=0x555555e01db0, e=0x7fffffffc950)
    at kernel/qapplication.cpp:3198
---Type <return> to continue, or q <return> to quit---
uwestoehr
Postby uwestoehr » Sat Feb 15, 2020 4:03 pm
Thanks for confirmation. This is now issue #4266.
wandererfan
Postby wandererfan » Mon Feb 17, 2020 12:17 am
Should be fixed bygit commit e8417c6268.
vocx
Postby vocx » Mon Feb 17, 2020 6:22 am
It was already merged. So I tested again, and no crash with 0.19.19624.
uwestoehr
Postby uwestoehr » Mon Feb 17, 2020 11:15 am
Many thanks! The crash is gone but the behavior differs from what is written in the Wiki. Here a list of issues I noted:
- one cannot add a leader and then select the Base View it should be attached to
- when selecting a view first and then adding a leader one can later also not change the Base View. I think this is sensible. I only wondered that I cannot find a case where the Base View Combobox is active in the dialog.
- when selecting 2 points to draw a line the result is always a horizontal line, not the line one has drawn:
screencast of the line selection issue
Maybe the drawing style guidelines require horizontal lines but then the second point pick must be horizontal to the first one.
- insert an annotation, select it and add a leader line to it
result: the leader line appears in the tree not under the annotation:
tree view
- if you haven't picked any point on creation time, you can later not add points -> you must create a new leader instead
wandererfan
Postby wandererfan » Mon Feb 17, 2020 2:07 pm
Didn't think it was possible to create a leader without a base view using the Gui. Are you using Python?
The BaseView field is display only. I guess it could be modifiable.
- when selecting 2 points to draw a line the result is always a horizontal line, not the line one has drawn: YHq6CG45jH.gif
AutoHorizontal property?
result: the leader line appears in the tree not under the annotation: FreeCAD_tUbj4pfk0o.png
if you make a leader, then add an annotation, does the tree look right? Don't think annotation knows how to handle children.
Knew about this one. It's on my list but I don't know when I'll get to it.
uwestoehr
Postby uwestoehr » Mon Feb 17, 2020 6:46 pm
OK, then I'll try to change the dialog to make it more clear it is a display. I don't use Python.
Yes, but this is what I mean - the user explicitly sets the points as he did, therefore the AutoHorizontal should not by default be enabled in the preferences. If the user needs this for a certain leaders he can do this or he can set the preferences option. Then he know what is going on.
-> I'll make a PR
The question is if this can be changed. It is not an important point but I think all TD elements should be able to handle children in future.
OK.
wandererfan
Postby wandererfan » Mon Feb 17, 2020 9:18 pm
-> I'll make a PR
There is already a preference for it, but it needs to be added to the preference screens.
    Base::Reference<ParameterGrp> hGrp = App::GetApplication().GetUserParameter().GetGroup("BaseApp")->
                                         GetGroup("Preferences")->GetGroup("Mod/TechDraw/LeaderLines");
    bool result = hGrp->GetBool("AutoHorizontal",true);
