chrisb wrote: ↑Sat May 01, 2021 10:54 pm
So it is recognized by FreeCAD, that there is a problem.
Hi chrisb
Yes, there is a problem on FreeCad but what happened to me is really curious:
- once the run_the_race file is opened the problem (at least on my system) is repeated even creating new objects.
Before, as you can see on the gif in my previous replica to run_the_race, everything worked correctly, now if I create a new object (starting from a sketch or a Draft wire) also on a new file and create a view on TechDraw the line of center between two lines behaves incorrectly.
Can you check if it happens to you too, even by creating a new file?
However, this is not a problem, just check the flip option and everything is solved, but the fact remains that the function behaves incorrectly (and this after opening the run_the_race file).
In my opinion developers should also investigate the run_the_race file to see if this file, in any way, changes a FreeCad parameter making it default without the possibility of resetting it through properties or preferences.
