[SOLVED] Change welding symbol size
mickele
Postby mickele » Thu Apr 09, 2020 7:37 am
I would like to change welding symbol size, sometimes it's too big compared to text.
Is there a variable I can set to change its size?
OS: Windows 10 (10.0)
Version: 0.19.20477 (Git)
Hash: 7d8ab175a68e476427e6e337fe3099b52da49dc8
Python version: 3.6.8
Qt version: 5.12.1
Locale: Italian/Italy (it_IT)
welding.FCStd
(19.07 KiB) Downloaded 3 times
wandererfan
Re: Change welding symbol size
Postby wandererfan » Thu Apr 09, 2020 5:12 pm
There is a scaling factor for the symbols:
Tools > Edit parameters> Preferences > Mod > TecDraw > Decorations > SymbolFactor
Add the parameter if it is not there. The default is 1.25 if the parameter is not found, so you'll want
to set it to 1.0 or maybe even less to make smaller symbols.
I'll add this to the preference pages.
mickele
Postby mickele » Fri Apr 10, 2020 2:18 pm
Thanks!!
Your suggestion solved my issue.
wandererfan
Postby wandererfan » Fri Apr 10, 2020 4:56 pm
SymbolScale parameter should be available on tab 2 of preferences after git commit b2a7cb9303
