Section view broken?
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Post by babaroga »
Hello,
I was trying to hatch section view on drawing but i cannot highlight surface. On mouse hover it turns yellow but on mouse click it does not turn green.
For my test, shape is basic, only 100x100 mm pad.
I created drawing and made section view. Then I tried to hatch section surface but I cannot select surface. It turn yellow when mouse cursor is over it but I cannot select it. I don't have any errors in report window.
In my settings I have:
Detect faces -> True
Show section edges -> True
Transparent faces -> True
Hatch -> Black
Geometric hatch -> Black
My Freecad is :
OS: Manjaro Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.20877 (Git)
Hash: 607c3a63952baeadc03be3eec89a9161f88dc890
Python version: 3.8.2
Qt version: 5.14.2
Coin version: 4.0.0
OCC version: 7.4.0
I didn't use this feature for some time but but on older drawings it worked... Am I doing something wrong?
Box2.FCStd
(26.87 KiB) Downloaded 23 times
wandererfan
Re: Section view broken?
Post by wandererfan »
babaroga wrote: Sat May 02, 2020 12:25 pm I was trying to hatch section view on drawing but i cannot highlight surface. On mouse hover it turns yellow but on mouse click it does not turn green.
Section cut face is not selectable if cut face formatting is in effect.
Section is set to have a PAT file hatch applied automatically:
Not sure why the PAT hatch is not applied. If I use my local PAT file, the hatch is displayed.
If you want to apply your hatches manually, you will have to hide the cut surface first. Then you can hatch as a regular face
babaroga
Post by babaroga »
Thank you for tip.
There is one strange thing. When I create section, there is no hatch, but If I change Cut Surface Display to anything and change it back to PatHatch then it shows up. Also, I can save document an reopen it.
Can you also look at attached model. Why is horizontal section bigger than original shape? Vertical section seems OK.
FEN2K Fronta ladice.FCStd
(98.53 KiB) Downloaded 24 times
wandererfan
babaroga wrote: Sat May 02, 2020 2:59 pm Can you also look at attached model. Why is horizontal section bigger than original shape? Vertical section seems OK.
ProjectionGroup Scale is 0.375.
Section - 001 Scale is 0.375.
Section Scale is 0.750.
babaroga
Post by babaroga »
Yes, I know that, but it is set to automatic. Why it does not have same scale as main view?
On my file in first post, all settings were the same and horizontal section have same scale as main view. If TD calculate scale according to available scale, on this drawing there is even more space.
THX
wandererfan
babaroga wrote: Sat May 02, 2020 6:05 pm Yes, I know that, but it is set to automatic. Why it does not have same scale as main view?
AutoScale only scales down to fit a View on the page. It doesn't scale a View if it already fits.
Sections always start with the same scale as the source view.
If the horizontal section was created before Front was auto scaled, and the vertical section was created after Front was auto scaled that would give the result you have.
