- TD_TD_02.png (57.2 KiB) Viewed 2845 times
Tangential dimensioning
Re: Tangential dimensioning
uhhhm
That is very odd - I even have a similar version:
Did you select the edges in different order? (it should not matter, but who knows)
OS: Debian GNU/Linux bullseye/sid (i3/i3)
Version: 0.19.20802 (Git)
Hash: f4279f1bea8377a7ef63f7f4c69b67159d498965
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: German/Austria (de_AT)
Works like expected on:
OS: Windows 10 (10.0)
Version: 0.19.20052 (Git)
Hash: 6291921e9abe737e4440ff5814ca58547defadef
Qt version: 5.12.5
OCC version: 7.4.0
Locale: German/Switzerland (de_CH)
Qt version: 5.12.5
OCC version: 7.4.0
@wandererfan: Was something changed with respect to the cosmetic vertices?wandererfan wrote: ↑Fri May 08, 2020 10:26 am Version: 0.19.20802 (Git)
Version: 0.19.20943 (Git) AppImage
I can confirm that 20802 vs 20943 has different results! Looks like the coordinates are flipped.
Is the conversation between drawing space and coordinate space not necessary anymore?
- wandererfan
getVertexByIndex() and getEdgeByIndex() now return drawing space coords.
https://www.forum.freecadweb.org/viewto ... 35&t=45705
I see. that makes it obviously easier to calculate the coordinates but now I need to add some backwards compatabilitywandererfan wrote: ↑Fri May 08, 2020 1:12 pmgetVertexByIndex() and getEdgeByIndex() now return drawing space coords.
Thanks!
Works flawlessly even with scale 2:1. What about tan, LINE, line --> parallel to LINE?
To give the last leg a possibility to get realized in the real life.
can you draw it in the sketch what dimension that should be? I can not really imagine
Of course,
Hello together,
Any plans to implement into the main branch?
Cheers,
PeterPNoster
Cheers,
PeterPNoster
