PeterPNoster wrote: ↑Sat May 09, 2020 3:27 pm
Of course,
From the perspective on one who's been asked (maybe too many times) to build something from a drawing I'd like to comment.
(Feel free to ignore)
The dimension really isn't 'useful'.
If you gave the length of the straight AND the degrees of wrap on the angular those dimensions would help the fabrication.
Giving just the dimension (length) as its drawn would mean that I would have to calculate the other dimensions - - - - without an easy way to do that.
Suggest that perhaps both ideas (the dimension and the 2 numbers that develop the idea) be included.
PeterPNoster wrote: ↑Mon Sep 21, 2020 7:59 pm
Hello together,
Any plans to implement into the main branch?
Cheers,
PeterPNoster
Greetings to the whole community
Here is a comparison of a technical drawing.
The one with another cad is complete, precise and very detailed (it is also possible to define the interruptions of the lines that cross)
You can appreciate the dimensions of any curve taken in tangency and also the development of the arcs.
(I am well aware that some dimensions are not needed for construction, but could be used for other industrial purposes)
domad wrote: ↑Thu Sep 24, 2020 8:25 pm
Very interesting. Wouldn't have thought that the line interruptions do improve so much the readability of complex dimensions. I am sure its a hell of a feature to develop
Thanks for the post.
catman wrote: ↑Fri Sep 25, 2020 8:48 pm
Hi catman
…… here is another example of complete, precise and very detailed dimensioning (also in 3D) obtained with the free 3D software “pCon.planner STD”.
I hope the developers take this sw as an example to try to code this efficient and productive sizing system on TechDraw
Hello community
I'm happy that the discussion continues related to this quite important topic.
A powerful dimensioning process will improve the TechDraw workbench a lot.
Here is a proposal for such a process:
I guess that is a more general question how to deal with the shear amount of macros. Unfortunately, the macro system in FreeCAD is not that advanced to add buttons into workbenches automatically, and writing modules for each little macro is a bit overkill.
Thus, do you have any suggestions how such macros might get integrated into techdraw?
Having them in git is certainly a good starting point. Unfortunately, there are also a lot of great macros just saved as attachments here in the forum.
PeterPNoster wrote: ↑Sun Sep 27, 2020 8:45 am
Hello community
A powerful dimensioning process will improve the TechDraw workbench a lot.....
Good morning to the whole community!
"The power and flexibility of Draft in terms of dimensioning "annihilates" TechDraw…" here is the demonstration.
There is no doubt that the "Create a dimension" tool should also be improved a little from a graphic, functional and editing point of view (the images are quite eloquent) but this does not detract from the excellent performance, in particular, also in quoting various tangencies....
reox wrote: ↑Fri May 08, 2020 10:41 am
@wandererfan: Was something changed with respect to the cosmetic vertices?
I can confirm that 20802 vs 20943 has different results! Looks like the coordinates are flipped.
Is the conversation between drawing space and coordinate space not necessary anymore?
getVertexByIndex() and getEdgeByIndex() now return drawing space coords.
Very nice work very happy, I didn't realize there were so many tools, love all of them...
Cheers
Haggis
PS I don't suppose you know how to make the cosmetic vertex smaller? I've set the default size smaller
but I cannot find where to adjust the cosmetic ones
Could some one put all these solutions together into an elegant dimensioning process?
Hello together,
Based on reox excellent work, could it be possible to implement the following dimensioning function?
The wish is to have the 'line - tangent - oriented on vector dimensioning possibility as shown here: https://forum.freecadweb.org/viewtopic. ... 20#p396922.
