Fine, Thanks a lot !
By the way it comes to me a question ...
How TechDraw manages to render views from the 3D objects ?
So, I think TechDraw use OCC to do the job, and I understand that OCC names view elements (edges, points, etc ...) arbitrarily, and then there is no way to link an element from the view to a 3D object element.
But, in a view where multi 3D objects are rendered, is there a way to know from which 3D object comes from edges, points, surface ?
Maybe not at the end of the process when the view is drawed, but before or during the rendering process ...
The idea behind my question is : can we change the way to render each objet (eg. change the line style)
For example, it would be usefull for cut view of part with screw : in a drawing we cut parts but not screws which are showed uncut
Or for a thread is an other example :
- Capture filetage 3D.PNG (12.62 KiB) Viewed 1542 times
- Capture filetage top.PNG (15.21 KiB) Viewed 1542 times
- Capture filetage coupe.PNG (13.38 KiB) Viewed 1542 times
