Ticket #4396 - TechDraw templates disappearing.
Re: TECHDRAW templates disappearing.
wandererfan
Your statement "a file selection dialog that changed directories without user input" is a good way to describe what I seem to be seeing. I already created my own directory per your suggestion. It works but is rather strange because the file selection dialog keeps changing.
I saw your Known OS specific issues but it did not dawn on me that it applied to this situation. Could you please explain how to use your workaround, I am rather confused.
Thank you.
Thank you.
It's these three steps:
1. Open Menu->Tools->Edit Parameters
2. Navigate to BaseApp/Preferences/Dialog
3. Create a boolean parameter named: DontUseNativeDialog and set its value to true.
Where do you get stuck?
I follow your instruction up Create a boolean parameter. I can't seem to create the parameter.
I just tried to create such entry on a plain vanilla configuration which crashed FreeCAD, can someone please confirm:
- Start FreeCAD
- Open Tools->Edit Parameters
- Select BaseApp->Preferences->Dialog
- Righ-click in the right panel of the window
->Crash
- Start FreeCAD
->Crash
That's what happened when I tried.
Please create a ticket in the bugtracker and crossreference this topic.
- wandererfan
I already had the DontUseNativeDialog set in my config file. That must be why my results were different.
Trying to add the parameter to an empty preference file fails here with:
OS: Linux Mint 19 (X-Cinnamon/cinnamon)
Version: 0.19.
Branch: unknown
Hash: ddf0cf3136a6c5a459abae4bf1f9c714f6f45c86
Python version: 3.6.9
Qt version: 5.9.5
Created a bug ticket issue #4396.
Reason: added bug bbcode tag
I saved the templates in a personal folder in my Documents, I did the same with the hatch patterns...
Re: Ticket #4396 - TechDraw templates disappearing.
Mod edit: Added ticket number to thread title.
Is this just AppImage related ?
