Feature #3011 - TD broken view
ggarner
Postby ggarner » Wed Jul 15, 2020 1:46 pm
Techdraw would benefit from a similar feature such as that shown here: http://help.solidworks.com/2012/English ... K_VIEW.htm
You can use a broken (or interrupted) view in a drawing. Broken views make it possible to display the drawing view in a larger scale on a smaller size drawing sheet. You create a gap or break in the view using a pair of break lines. Reference dimensions and model dimensions associated with the broken area reflect the actual model values.
If there is consensus on this feature, then I may work to help implement it.
Reason: Added ticket number to thread title
nic
Re: Proposed feature: broken view
Postby nic » Wed Jul 15, 2020 2:29 pm
+1
Postby chrisb » Wed Jul 15, 2020 2:30 pm
Would sure be good to have. It was already mentioned several times.
Postby Kunda1 » Wed Jul 15, 2020 3:23 pm
is there an open issue in the tracker ?
wandererfan
Postby wandererfan » Wed Jul 15, 2020 7:39 pm
issue #3011
Postby Kunda1 » Thu Jul 16, 2020 12:11 am
issue #3011
:oops: I forgot that I opened that in 2017
thebighaggis
Postby thebighaggis » Sat Jul 25, 2020 5:03 am
I vote for that too :-)
Would be very handy on a job I'm doing right now..
I had to use Inventor to do the drawing..
Cheers
Haggis
Broken View.jpg (71.36 KiB) Viewed 122 times
Re: Feature #3011 - TD broken view
Postby Kunda1 » Sat Jul 25, 2020 11:57 am
This has been a Feature request for a while. I'm sure people would like to see this implemented. Are you going to take a stab at it?
