Break Line
Break Line
Hi all!
I try to create a tech draw of a very long but thin part. If I scale that the length fit the top view is too small and if the top view fits the length is too long for the drawing. Is there a "break line" function so that both views can have the same scaling but the long part is fitting on the drawing (and is broken apart in the middle)?
Thanks!
Thanks!
Re: Break Line
Hi and welcome to the forum!
This is not implemented yet.
Re: Break Line
Re: Break Line
It was discussed before and I think that wandererfan has it on his personal todo list.
Re: Break Line
Since Wandererfan has taken a leave of absence, and this is IMHO something that is quite useful, is there any path forward for this feature? I wish I could help, but this kind of coding is way out of my league.
In case anyone is interested, here's how SolidWorks does it
Re: Break Line
You can create a feature request in the tracker. Crosslink it with this and - if you find it - the old discussion.
Re: Break Line
Good evening to the Community, welcome to the new year, we hope that at least it will be better than 2020.
FC-TechDraw already has the tools to accomplish this, as I told chrisb I will soon publish a small guide to explain how to do this and more. TechDraw without limits.
- TechDraw_long-shaft.png (123.59 KiB) Viewed 3916 times
Re: Break Line
Awesome! This looks really good!domad wrote: ↑Sun Jan 03, 2021 1:56 pm Good evening to the Community, welcome to the new year, we hope that at least it will be better than 2020.
Even if the guide will surely explain it in detail, could you give me some pointers to how you got this? I've researched the wiki, and tried all the options I could think of, and could not find any way to get anywhere close to this. I tried looking at your design tree, but I got nothing useful out of it. I'm still a newbie when it comes to Freecad, so I could have easily overlooked something critical
Alternatively, if you could share the freecad file, I could at least try to reverse engineer what you did.
Re: Break Line
Hello ToniTen! Good evening to the communityToniTen wrote: ↑Tue Jan 12, 2021 5:14 pm ............
Sorry if I reply late, but I was already working to give you as complete an answer as possible.
Here you will find what you ask for: https://forum.freecadweb.org/viewtopic.php?f=35&t=54499
Buon lavoro e sperimentazione!
Re: Break Line
So I just wanted to share my solution for this:
- Create the view you would like to use for a break line
- Create an identical copy of this view
- Create two empty clip groups and put the two views in each
- Adjust positions of the views inside the clip groups and the sizes and positions of the clip groups so that they align perfectly
- Use the Leaderline to add a break line to each of the clip groups
- Add dimensions as needed.
