vanuan wrote: ↑Fri Sep 18, 2020 3:41 am
bitacovir wrote: ↑Tue Sep 15, 2020 6:08 pm
I created a Section plane on a cube in ArchWB
Then, I created a ArchView from that section plane in Techdraw
When the section plane cuts the cube, the ArchView shows the section of the box in the Techdraw.
But if I move the section plane outside of the cube, the ArchView does not show anything.
Seems like a bug in the Arch view rendering engine. Which render mode do you use? It looks like Wireframe and Solid have this issue, while Coin renders it properly.
Is it a regression? Maybe it never worked? Cube isn't an architectural object, after all.
yes I have the problem with Wireframe rendering.
Section planes used for facade rendering with ArchView in TechDraw has been used as normal workflow by Yorik and me. You can verify it in this chapter of the Manual BIM modeling:
https://wiki.freecadweb.org/Manual:BIM_modeling
Also, you can verify with the ArchDetail model included as example file in FreeCAD installation. In this model, the Section A is to display an elevation view:
- freecad_05XOSw92tk.png (77.33 KiB) Viewed 504 times
I have tested this example model in two freeCAD installations: 0.18.4 and 0.19 creating a TechDraw page and an archView without any manipulation of the model. It works fine in the first case, but it does not work in the second installation.
- FreeCAD_7lP8R20xyC.png (103.05 KiB) Viewed 504 times
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
- freecad_vo2FNtYhED.png (95.19 KiB) Viewed 504 times
OS: Windows 10 (10.0)
Version: 0.19.22411 (Git)
Hash: d4519d5aec15bc08f029da5ed15410a494b57b2c
Python version: 3.8.5
Qt version: 5.12.6
OCC version: 7.4.0
