[Solved] ArchView only shows objects if section plane cuts through them
I created a Section plane on a cube in ArchWB
Then, I created a ArchView from that section plane in Techdraw
When the section plane cuts the cube, the ArchView shows the section of the box in the Techdraw.
But if I move the section plane outside of the cube, the ArchView does not show anything.
Section plane cutting the box section plane no cutting the box OS: Windows 10 (10.0)
Version: 0.19.22411 (Git)
Hash: d4519d5aec15bc08f029da5ed15410a494b57b2c
Python version: 3.8.5
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Re: ArchView only shows objects if section plane cuts through them
FC Version: 0.19.22411 (Git)bitacovir wrote: ↑Tue Sep 15, 2020 6:08 pm I created a Section plane on a cube in ArchWB
Hello bitacovir
The cut is visible at a maximum distance of 1.00 mm.
No sight at 1.10 mm
I hope I helped you solve the "mystery"
- 1.png (47.33 KiB) Viewed 2163 times
I use the Section plane to create ArchViews of building facades... The plane is several centimetres or meters from the walls. still it is not working...domad wrote: ↑Thu Sep 17, 2020 8:57 pmFC Version: 0.19.22411 (Git)bitacovir wrote: ↑Tue Sep 15, 2020 6:08 pm I created a Section plane on a cube in ArchWB
Hello bitacovir
No sight at 1.10 mm
::bitacovir::
Seems like a bug in the Arch view rendering engine. Which render mode do you use? It looks like Wireframe and Solid have this issue, while Coin renders it properly.bitacovir wrote: ↑Tue Sep 15, 2020 6:08 pm I created a Section plane on a cube in ArchWB
Is it a regression? Maybe it never worked? Cube isn't an architectural object, after all.
Greetings to the whole community!
I think there is nothing unusual, you need to be a little more "inventive" ..... can you do the same or not?
This is the result of what I explained earlier ...
I hope I was clearer
- 2.png (30.53 KiB) Viewed 2098 times
I don't understand what you're telling. Clearly, walls are displayed but the cube is not. Are you saying it is because the cube is very small?
Hi "vanuan", pleasure of knowledge, the cube is absolutely visible even if very small, I was just pointing out a way around the bitacovir problem:
"I use the Section plane to create ArchViews of building facades... The plane is several centimetres or meters from the walls. still it is not working..."
- 3.png (33.51 KiB) Viewed 2077 times
yes I have the problem with Wireframe rendering.vanuan wrote: ↑Fri Sep 18, 2020 3:41 amSeems like a bug in the Arch view rendering engine. Which render mode do you use? It looks like Wireframe and Solid have this issue, while Coin renders it properly.bitacovir wrote: ↑Tue Sep 15, 2020 6:08 pm I created a Section plane on a cube in ArchWB
Section planes used for facade rendering with ArchView in TechDraw has been used as normal workflow by Yorik and me. You can verify it in this chapter of the Manual BIM modeling: https://wiki.freecadweb.org/Manual:BIM_modeling
Also, you can verify with the ArchDetail model included as example file in FreeCAD installation. In this model, the Section A is to display an elevation view: I have tested this example model in two freeCAD installations: 0.18.4 and 0.19 creating a TechDraw page and an archView without any manipulation of the model. It works fine in the first case, but it does not work in the second installation.
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
::bitacovir::
Ok. A regression then. I can reproduce the issue in the AppImage version from around June 20.bitacovir wrote: ↑Fri Sep 18, 2020 12:29 pmyes I have the problem with Wireframe rendering.
Which means a regression happened not later than in May:
https://github.com/FreeCAD/FreeCAD/comm ... onPlane.py
Here's a start of the Wireframe rendering code
https://github.com/FreeCAD/FreeCAD/blob ... ne.py#L455
Let's see whether there's something obvious.
....here are the experiments I tried, they could be useful to solve the problem
- 1b.png (86.58 KiB) Viewed 2010 times
- 2b.png (50.35 KiB) Viewed 2010 times
- 3b.png (93.25 KiB) Viewed 2010 times
- 4b.png (48.3 KiB) Viewed 2010 times
