Create a technical drawing
Hi all,
I need your help. I did several drawings in TechDraw but this time it's difficult and I don't even know if it is possible. I would be grateful for tips and advices.
I need to send this technical drawing for manufacturing.
Here is the final design (FreeCad v0.19):
https://drive.google.com/file/d/1zX2hF9 ... sp=sharing
The pulley (T10, with 28 tooth) is created in openScad and then all the inner features are made in FreeCAD.
- pulley.png (45.15 KiB) Viewed 3755 times
Re: Create a technical drawing
Hi Michal, what times are there? Since no one is proposing, I could work on it this weekend.Michal wrote: ↑Wed Oct 14, 2020 1:41 pm Hi all,
Hi domad,
no hurries. There is plenty of time. Thank for your reply. Do you have any ideas?
I actually got one after couple hours.
I though I could use symmetry and say that the pulley repeats every 120°. But I'm not sure if this is possible. It requires a little bit playing around with lines etc. But in general it might work.
There are some "issues" like four mounting holes for the hub they are not fit for 120° and the section is not quite right too.
(I did use simplified part since the openScad feature is terrible slow. And the 120° part I created with Groove feature from full pulley)
This is just an idea and a draft:
Hi, MichalMichal wrote: ↑Thu Oct 15, 2020 8:10 am Hi domad,
This is essentially the technical drawing that needs to be produced in TechDraw.
I hope to do it, as I anticipated, on the weekend also through another sw, as some dimensions in TechDraw, at the moment, cannot be inserted and then because it is very slow.
I will also try to do this through the use of Draft's "Creates a dimension" (lightening the model a little)
- 1.png (37.12 KiB) Viewed 3598 times
Hi domad,
that's wonderful how you approach this I'll definitely try it myself. I see the main problem here in the slowness.
I tried to draw the pulley from scratch but I was not successful due to overlapping issues when PolarPattern was used. So I used a openScad and a generator https://www.thingiverse.com/thing:16627
Do think that there is another way how to avoid openScad and thus the slowness?
Fillets and chambers - I usually do them as a last thing. This time I forgot add fillets at all. I'm sorry for that here is a new file.
https://drive.google.com/file/d/1CIA0S2 ... sp=sharing
Hi, MichalMichal wrote: ↑Thu Oct 15, 2020 5:17 pm Hi domad,
I tried to draw the pulley from scratch but I was not successful due to overlapping issues when PolarPattern was used. So I used a openScad and a generator....
I attach the technical drawing in * .pdf format made with another cad.
At present it is difficult and slow to do it with TechDraw or with "Creates a dimension" in Draft.
- technical_drawing_pulley.pdf
- (215.35 KiB) Downloaded 63 times
- tec.png (110.39 KiB) Viewed 3336 times
Hi domad,
it's great job what have you done. I really appreciate it. Thank you.
Good evening to the whole community!
Hi Michal
Here is the result of the technical drawing made with the Draft tools and with “Creates a dimension”.
The layout is very reminiscent of that of autocad, that is, directly in the model view (it is an anomalous (although functional) way of paging because layouts very similar to TechDraw sheets are available in that cad but immensely more flexible and powerful.
If these tools were integrated into TechDraw, any technical drawing (of any field) could be made without any limitation.
Once again Draft proves to be much more flexible and powerful than TechDraw.
- technical_drawing_pulley-draft.pdf
- (68.72 KiB) Downloaded 83 times
- Tec-Draft_pdf.png (102.52 KiB) Viewed 3120 times
- Tec-Draft1.png (68.44 KiB) Viewed 3120 times
- Tec-Draft2.png (40.37 KiB) Viewed 3120 times
- Tec-Draft3.png (88.34 KiB) Viewed 3120 times
The result:
Thanks. Re: Create a technical drawing
Hi Michal, greetings to the Community!
Great result! The warmest congratulations! (I'm "open-mouthed")
The realization of a project fills us with great satisfaction, this demonstration of yours makes FreeCad bigger and bigger. This is a great demonstration that FreeCad is ripe with flying colors for professional and industrial use. In these past months I have continued undaunted in the study of possible solutions to use TechDraw without "limitations" and finally I have made public a workflow that allows you to use TechDraw at maximum power. Today it can also count on a macro (already in the master) developed by a large “edi” that further enriches and speeds up the dimensioning and tracing tools with which TechDraw is equipped.
Here you can find the English tutorial (step-by-step) of the workflow: https://forum.freecadweb.org/viewtopic.php?f=35&t=54499
Here the wiki: https://wiki.freecadweb.org/Advanced_TechDraw_Tutorial
Here the topic and the macro of "edi": https://forum.freecadweb.org/viewtopic.php?f=35&t=55029
I think (as advice) you should post the post on the "Users Showcase" forum
Greetings by renewing the best compliments!
